Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Audio on Sharp LC-32d43u
I've had my sharp tv for 2 years and all of sudden the sound went off and now there's no audio. The tv isn't on mute and the cable volume is to the max and there's still no sound. I've also tried unplugging it and that still doesn't work. It's currently connected to the cable box with an hdmi cord. How do I fix this?
    Problem Solver:
  • 17 Answers
If you had sound for before and then lost it (without changing any settings), then try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service (1-800-237-4277) and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Posted on Aug 23, 2009
    Sergeant:
    Champion:
  • 227 Answers
The sound card is bad on your tv, the only inconvenient is that if you replace it, it will go bad again, so  your solution is to get the sound from your cable or satellite box and go through a receiver or amp. basically what i am saying is "build a little home theater" to get the sound and don't waist your money trying to fix it.
good luck
Posted on May 27, 2009
2 Suggested Answers
SOURCE: I bought the Sharp TV LC-32D43U in 2007. Now it
Well for a start, they are NOT all the same models, also. a certain percentage, are expected to, and do fail. You see for a good repair, you need to contact, a local Sharpe, office, and ask, for a referral, to an Authorised Service Center, repairer. It is indeed worthwhile contacting Sharpe, as often, a service bulletin, has been issued, that maybe to do with your set, and if your set was in the repair bulletin, then you may even get your set fixed for free, or at the least very subsidized. So you see until, you contact, an Authorised Service Canter, and inquire, always ask for a "Quote" this way, you can find out what's wrong and how much, you can expect to pay.
Posted on Apr 24, 2010
I need a pedestal stand for a Sharp AQUOS LC-32D43U 32 in. LCD Television.
i need a pedestal stand for sharp aquos 32 inch tv and do not know where to get. check on line it seem no one has it. where can i get one? do not want to spend a lot of money not more than 50 dollars.
Aug 10, 2013 | Sharp AQUOS LC-32D43U 32 in. LCD...
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Sharp Model Aquos LC-32D43U
What is the problem you faces with this TV? Provide more details please.
Oct 06, 2012 | Sharp AQUOS LC-32D43U 32 in. LCD...
How to Fix the Vertical Line on your sharp lc-32d43u LCD TV
This is what they call "pixels", you can tap the picture with your fingers and hope it comes back on other than that get in contact with sharp regarding this. "Dead Pixels"
Aug 25, 2012 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp LC-60LE810UN. the sound all of a sudden cut out on the tv. everything on the tv seems to be working just fine. but there is no volume at all.
hi,
You have to check three things.
1. Check is the mute function is ON or not. For that press the mute button on the remote.
2. Check the speakers of you tv. For that you have to open the tv. For testing the speaker you need a multimeter. Check the coil continuity of the speaks. it should be 4 ohms or 8 ohms. If there is no continuity then change the speaker with a new one. If the continuity is ok then
3. You have to check the audio output amplifier IC ( integrated circuit). For finding out the audio amplifier ic which one it is, just follow the wire from the speakers. Its other end will ends in the socket near the audio output IC. It will be fitted on a aluminum heat sink (radiator)
To replace the IC you need soldering ion,desoldering pump, solder etc.
the part number will be written on it. you have to purchase the same part with the same part number.
ok
Apr 27, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Aquos LC-32D43U, no audio
My suggestion would be to bypass all of your video components whatever you have be it a vcr, dvd player,whatever and just hookup the tv direct to whomever you receive your cable tv from. Because it was working before you moved it and disconnected the external audio source. Remember if your using HDMI cables they are your audio and video together and you don't need to hookup anything else from that device to the tv. Just FYI. Good luck.
Jun 19, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound
Please try unplugging the TV for two minutes then replugging and turning it back on. Werked fir me!
Dec 12, 2008 | Sharp Aquos LC-32D40U Television
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
509 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
