Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Same happened to me but it seems to be part 9759242
Are there two thermostats in the Superba buil in oven? kebc177blo
Kitchenaid Superba Electra oven doesn't reach set temperature. When we set the temperature for 400, it only gets to 375. Is there any way to fix this?
sounde like a temperature probe going bad or thermostat out of adjustment .ask your parts dealer if your oven uses a temperature probe or thermostat.
Oct 19, 2013 | Ovens
After using the self cleaning feature of our Kitchenaid KEBC107KSS single wall oven, it will not heat up. After reading numerous complaints from other people with a similar problem it seems there is a...
If you slide your oven out and take off the center panel on the back of the oven you will see the thermal fuse. If it's like mine, it will be located (looking from the back of the oven) upper right hand side. It's an oblong loooking part with two terminals with wires attached to it and two screws holding it on. Once you take it off, you will notice that it is flat on the back side and you should be able to see part # 9759242. Only reason I know this is that I have just removed mine and am going to see if I can find one locally. Same thing happened to mine after putting it in the cleaning cycle to clean up after the holidays.
Hope this helps!
Robert
Dec 26, 2010 | KitchenAid Architect Series KEBC107KSS...
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a Kitchenaid oven model KEBC107KSSO. After using the auto clean, broiler and oven does not heat. Control panel works fine.
The thermal fuse on the back of the oven is out. Usually happens if the oven is installed incorrectly or the blower is too small to cool the back of the oven down while in self-clean mode.
I'd call KitchenAid (whirlpool) and ask if it needs the blower kit to fix it. Have your model&serial numbers handy.
In case it does not need the blower kit, the thermal fuse part number is 9759242, and it can be purchased here (use coupon "New10" for 10% off). Read my other post for the instruction how to get to the thermostat.
Oct 14, 2009 | Ovens
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Error Code F5 E5
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Sep 05, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid kebc107 not heating
You need a themostat part #9759242
Your welcome
Jamie
PS Its easy to install!!
Oct 10, 2007 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
300 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
