Question about Acer Computers & Internet
Acer Aspire 5920 not turn on
My laptop not turn on .The AC/ work fine,bat the computer not turn on
  • nygaspar May 26, 2009
    not work
  • Acer Master
  • 4,806 Answers
Hi there.
Try taking the battery out and run it on AC power only.
If this does not work please post back for additional advice.
Good luck and thanks for using FixYa!!
Posted on May 26, 2009
No power from battery to laptop
are you installing it with correct polarity
is one of the battery terminals in the laptop damaged so that it is not making contact
May 22, 2017 | Acer Computers & Internet
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
Jun 14, 2011 | Acer Aspire 5920-6706 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 won't turn on
check the ram chips havent come loose, i had this problem with an acer aspire 5315 (fixed myself). if that doesn't work, check the lcd cable
Dec 26, 2009 | Acer Aspire 5920-6727 Notebook
Aser Aspire 5920 Will Not Switch On
it must b some problem with the RAM......get the ram changed ...den it will work fine
Sep 02, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Crystal eye web cam not found on aspire 5920
Acer aspire has inbuilt web camera and therefore will work only if the correct drivers are installed. Please uninstall the drivers first from control/panel/add remove programs. Next reboot the system and then go ahead with the installation.
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
Thank You for using Fixya.com
Jul 26, 2009 | Acer Aspire 5920-6727 Notebook
My acer apsire 5920-6423 worked fine, now it has just a blank
I have had the same problem with my 5920 and when it does what yours is doing have to <ALT> <F10> to reset to factory settings. this has now happened 3 times in 7 days, so is going back under the warranty, as have spoken to an IT guy who says its a major problem and cant be fixed. hope you get yours sorted
Jun 13, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920-6864 Is not turned on
this probleme is common among acer 5920, the probleme is with the motherboard that's of bad quality and workmanship. Acer should be ashamed to sell a PC with a faulty motherboard and should compensate all 5920's owners or replace with a better motherboard. 1000's if not millions are having the same probleme wich tell to anyone with a brain that Acer 5920 is a scam. good luck. x
Dec 20, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
