Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 ( power works, but no picture.)
When i push the power button, the green light comes on briefly then goes off. I unplug the set for 30 seconds then plug it back in. The same thing happens. I leave it alone and the green light will come back on and go off by itself and still no picture or sound. The TV will come on every once and a while and play Great!. Now it is really hard to get it to come on. PLEASE HELP!
  • 147 Answers
There are four bad capacitors on the sweep board in the power supply. Pretty hard to do yourself unless you have some experience.
Posted on May 26, 2009
Have an RCA D52W20 When I push the power button the green light goes on and off about 3 or 4 time and quits never coming on at all.
That could be the CP150 CP120 and CP114 capacitors. You can get the RCA repair kiy by that same name from www.tvrepairworld.com which also contains the repair instruction CD.
Jul 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not stay powered up
this units processor has detected a fault and has shut it down for safety. This means it can be one of about 30 different cuircits that are at fault. this is where troubleshooting starts. technicians have special diagnostic equipment for rca that will read errors in the processor. are u a technician. there are basic voltage checks that can be performed. Warning televisions generate potenitally leathal voltages. do not remove back unless qualified.
Jan 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 in. does not come on!
d52w20 is an rca itc22 chasis. The processor in this unit is detecting a problem and for safety shutting the unit down. it can be one of many problems. technicians have special equipment to read the error log the procesor generates. The first thing a customer can try is to unplug the set for 30 min the plug back in and try again to restart the set. if this dont work i suggest u take it to a tech. if your a tech there are some first thing to check.
Jan 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light wont turn on, it started one time then went out, no power to tv scine then
if the green light never comes on. that is is if you unplug the set and wait 30 min before plugging back up. and then the green light never comes on..you have a power issue. the processor never receives power. if it comes on then goes out you have a shutdown issue. the processor detects a condition which it need to shut down the set due to a saftey issue. The processor generates a error log. which can be read by a technician and a computer. it can be one of about 30 different problems. so it would be best to troubleshoot this further.
Dec 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
193 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
