Question about RCA R56WH76 Projection Television
3d like picture, 3 colors bending across screen. convergence option gone from menu
I have an rca r56wh78 and picture is 3d like. 3 colors bending across the screen. convergence option is gone from menu. any idea what my problem is???
  • 147 Answers
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
Posted on May 26, 2009
The picture on my RCA R56WH78 is blurried
thats the ITC222A chassis which is famous for deflection board issues which cause misaligned colors. You can get free assistance to figure it out by responding to this same post and leeting me know if you still have the auto convergence option still listed under the setup menu or has it disappeared from the setup menu options.
Mar 18, 2013 | Televison & Video
Multi color jagged line across screen
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Philips Televison & Video
Wavy colors across the screen and the color has separated. ghosts on picture -four eyes ect. I can't adjust the convergence.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Samsung HCL4715W 47" Rear Projection...
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
Jul 19, 2009 | RCA R52WM24 52" HDTV Projection Television
3d rainbow pictures..with colorful waves..and no convergence menu to fix it.
You will need to replace the FL231, DL231 and CL230 you can get the parts with free instructions with pictures at the following link. The parts are all listed under the RCA parts category total cost is about 11.00 http://servicemanuals.vstore.ca/
May 14, 2009 | RCA HD61W66 61" Projection HDTV
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R56WH78 3D Color Spectrum
Hello The common FL231 fuse problem that these set has can be identified by asking the question DO you have the convergence option under setup in the customer menu. If you do not then there is a 99 percent chance you have this. I have written detail repair instrucitons on this under my profile in the tips and tricks section of fixya. I use union electronics for parts but just google the part and you can find many distribitors of the fuse. should not cost no more than 5 dolars and if you can solder the repair shouldnt take more than an hour to complete. Be carefull and good luck. This repair is on you can do if you have any trouble let me know.
Nov 07, 2008 | RCA R56WH76 Projection Television
Open Questions:
RCA R56WH76 Projection Television Logo
715 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
