Question about HP Computers & Internet
No wireless adaptor response
My wireless adaptor is not operative and can only connect to the net via ethernet
  • 115 Answers
Go to device manager by right clicking on my computer and then hardware and then device manager and under network adapters check for any wireless card,,if no,,then check for network controller,,if u find network controller then u need to install the drivers for the wireelss card from the drivers cd given by ur manufacturer,,if also u find the wireless card option under network adapter with a yellow bang beside it then also install the drivers of the wirelss card,,keep me posted
best of luck,,giv a good rating,,keep me posted
Posted on May 26, 2009
My internet connection via Ethernet vanishes when i disable my wireless connection. how can i keep this from happening. it's on a old Gateway MX6214 PC Notebook.
Sounds like it's connecting through wireless so when it's switched off, it stops.
Go to 'my computer' if you're using XP and right click, click 'properties'.
Go to hardware, then Device manager.
Look downlown list and choose 'network adaptors'.
See if both wireless and ethernet are working OK. Use properties to check.
Dec 30, 2010 | Gateway MX6214 Notebook
The SMTP server returned an error. Account: 'pop.012.net.il', Server: 'smp.012.net.il', Protocol: SMTP, Server Response: '-ERR Permission Denied', Port: 25, Secure(SSL): No, Error Number: 0x800CCC60
Most SMTP-servers will give "permission" to be used only when your computer is connected via an IP-address assigned to you (statically or dynamically) by the Internet Service Provider.
So, if you are using wireless Internet access, maybe provided at some retail location, rather than connected by Ethernet cable to '012.NET.IL', or wirelessly within your own home, using your own wireless router, you will get this error-message, when you try to "send" E-mail.
Feb 28, 2010 | Microsoft Windows XP Home Edition
My wireless wont work on my laptop
First of all let’s check if you have a wireless card in your laptop.
1 Right click my computer 2 click properties 3 Click hardware 4 Click device manager.
Look down the list and click the + on network adaptors you should see two adaptors 1 a Ralink RT2500 Wireless LAN card, or a 2000 or something like that to show it has a wireless card installed.
The second adaptor is a VIA Rhine II Fast Ethernet adaptor this is for the cat5 cable that would be connected direct to your modem for going on the net direct.
If there is no mention of a wireless card you have not got one fitted, if one is mentioned but it has a yellow mark next to it the card is not working has it’s not got a driver installed.
Let’s deal with the easy one first, card installed yellow mark i.e. no driver.
Connect the laptop via a cat5 cable direct to your modem or get on the net somehow.
Type in Fujitsu it will bring up lots of options click Fujitsu Siemens scroll down to support Fijitsu and it will take you to welcome to support page click on drivers and downloads.
This will take you to a page that you put your serial number in then all the drivers will be listed and you can download the wireless LAN driver.
Once the driver is installed you should get onto the net via wireless.
If no card is installed you can get one for a few £s off EBay. (teastheword will have one)
To install it read the post I put up on changing the COMS battery, you have to remove down to the RAM cover i.e. power strip keyboard RAM cover.
You should see two wires one black one gray the gray clips to the main terminal of the card and the black to the Aux, the card slots into the mother board.
If the laptop has a card and the latest driver installed and still will not connect it’s the Arial behind the screen or the mother board which is a common fault. I could talk you through changing that but at this stage it’s really a shop job.
You can still go wireless by purchasing a USB stick wireless adaptor this will act as you wireless card (Net gear wg111v3 or equivalent. Just plug it in load the driver and connect.
You would then have to load the driver as above.
Hope this solves your problem or helps.
Jan 16, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My medion akoya is not detecting any wireless networks and I can only connect to the internet via my ethernet cable.
In control panel, is wirelesss network adaptor turned on?
If NO wireless networks are detected and you know you should see some. Remove the wireless device from the system (in device manager) and restart the computer
Dec 19, 2009 | Computers & Internet
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
Router not connecting with adsl modem wirelessly
re-set it and re-configure it ur router then you get it
Mar 12, 2009 | Computers & Internet
Wireless Adaptor Issue
First make sure that your wireless router is set to broadcast (or if you prefer not to broadcast) your SSID (your wireless network name) or that your laptop wireless network connection properties is set-up to "Connect even if this network is not broadcasting".
To check this go to:
Click Start> Connect to>Show all connections>
Right click your Wireless Connection and select properties>
On the Properties box select "Wireless Network" tab >
Go to "Preferred networks" then highlight your SSID (network name)
Click "properties" button check "connect even if this network is not broadcasting". (while youre here check that your "Wireless network key" confgurations are correct).
Make sure that you are also set-up to "Obtain an IP Address automatically " and "Obtain DNS server address automatically"
To check:
Select "General" and under the heading "This connection uses the following items">
Highlight "Internet Protocol (TCP/IP) then click "Properties" button
Jan 10, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Vista Wireless Problem: Intel Pro/Wireless 3945ABG
Hi Pete,
You sound like you know what you're doing, so forgive me if these suggestions seem foolish or patronising..
Does your laptop have a wireless button?
When you go to Internet Options and click the Connections tab, have you checked 'Never Dial a Connection'? This is essential..
I have exactly the same ethernet card and network adaptor, but haven't had any problems, and we have 2 laptops and 2 pc's here all detecting our router okay so..
It's definitely not MAC filtering on the router, as you would still see the network in your list..
I can only suggest uninstalling the Intel Pro Wireless driver and downloading a fresh one from here.
That'll reset default settings at least..
Hope this helps
Let me know how you get on.. If I face this problem I want to know how to fix it too!
Chris (ziraffa)
Dec 27, 2008 | Intel PRO/Wireless 3945ABG Network...
I don't know how to connect to the net
If you have wireless, then go into wii options and it should be quite straightforward, if you have an ethernet cable, you need to buy a usb to ethernet adaptor, sorry
Jul 04, 2008 | Nintendo Wii Console
Computers & Internet Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
