Question about Eidos Interactive Tomb Raider: Chronicles for Windows
1ST LEVEL,WHERE DO i FIND KEYS TO THE GARDEN
WHERE DO i FIND THE KEYS TO THE GARDEN
    Sniper:
  • 82 Answers
COURTYARD WITH PALM TREES AND TIGHTROPE: Enter cautiously, Larson waits in the next room, up on a balcony to the left. Let him have it with your pistols and he'll run off shortly. Pick up a small medipak in the alcove on the right. Then go through the doorway below where Larson was standing. First go left down the ramp to a room with boxes. Here you'll find a GARDEN KEY (shaped like a star) on one crate.
Return to the hallway and continue left to the top. Larson will shoot at Lara again from the other side of the gap. Again, plug him a few times to scare him off. Then tightrope walk across to the opposite balcony. Drop down and, if you like, use the switch to open a gate leading back to the FOUNTAIN COURTYARD. (NOTE: As before, you don't have to do this, but it could save you some backtracking.)
Head away from the gate toward a WIDER STREET WITH A GATED GARDEN off to the right. This is where you'll use the GARDEN KEY, but you need another one first. Go to the left end of the street and through the small, square doorway. Follow the hallway, picking up some revolver bullets in a small room on the left. Make a mental note of the LOCKED WOODEN GATE with the small room behind it. This is the location of the second secret. You'll come back for it later.
Continue upstairs. Be sure to pick up the REVOLVER on the landing. (You probably won't miss it because the camera focuses on it so you're unable to look at anything else.) At the top of the ramp, push open the blue double doors. Inside this SMALL ROOM WITH WINE BARRELS you'll find the LASER SIGHT on the floor to the left and a padlocked gate on the right. Shoot the padlock: either use the revolver equipped with the laser sight to target it (check your instruction booklet or see the section on 'using the laser sight' on the TR5 controls page), or face the lock squarely and shoot continuously with pistols while crouching. Lara should hit the lock on the way down. Behind the gate is the second GARDEN KEY. A colony of rats swarms out. Some of these will try to bite Lara, so if you've gotten everything, run away downstairs. Or, run out, jump the railing and wait for the bats to disperse before returning to collect the key.
Posted on Jul 16, 2010
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
I have psr-s910, Recently it had a problem some of the keys sound too loud mostly (1st White & 1st Black key) i:e(c & c#)of four octaves. So how can i solve my problem?
touch response is not working of those keys, reason, contact rubbers are damaged, maybe you placed something heavy around that area. you will have to replaace the rubbers, or wait for it it might work well on its own..
Aug 05, 2014 | Yamaha Music
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
What could be the causes of oil pumping from crankcase tube to carb b/s 14 hp... other than broken oil ring??
worn compression rings , & oil control rings
worn bore ,
worn ring grooves -
loss of crankcase vaccumm , - c/case gasket broken/leaking
stuck breather ,
high oil level
blown head gasket ,
check simple things 1st
Aug 08, 2010 | Briggs & Stratton Garden
I want the service center address in delhi
These are some of the main service centers in New Delhi,
Digital Solutions Pvt. Ltd.
II nd Floor, Kanu Chambers, C-2,
Sanwal Nagar (Sadiq Nagar)
New Delhi 110049
Contact Nos. 91 11 26259696 /26258411
Service level: Onsite
Digitech E-Services
33-A, Industrial Area
Rama Road
New Delhi 110015
Contact Nos. 91 11 25432446/45085280
Service level: Carry -in & Onsite
Groovy Communications
207, Siddhartha Building,
96-Nehru Place,
New Delhi 110019
Contact Nos. 91 11 41612777/91 1126476555
Micro Max Technologies
P-31 West Patel Nagar
New Delhi 110008
Contact Nos. 91 11 25872327/39578440
RT Outsourcing Services Ltd
33-A, Rama Road,
Industrial Area, Opp Kirti Nagar Metro Station,
New Delhi 110015
Contact Nos. 91 11 -45085292 /45085280 /45085196 /450852810
Service level: Onsite&Bench
RT Outsourcing Ltd
A-200 (Building at Main Road )
Okhla Phase -1
New Delhi 110020
Contact Nos. 91 11- 44312600
Targus Technologies Pvt. Ltd.
F - 11 , First Floor, East of Kailash
New Delhi 110065
Contact Nos. 91 11 41646541 / 26217116
TechnoLand Systems Ltd.
A2/177
SafdarJung Enclave
New Delhi 110029
Contact Nos. 91 11 26191221,/26191331/ 26191441
Insight Communications
S-6, 1st Floor, Okhala Industrial Area,
Phase II,
New Delhi
Contact Nos. 91 11 30882726/ 30882727
Service level: Onsite IPG Value only
Agmatel India P. Ltd
B-28,
Patparganj Industrial Area
NewDelhi 110092
Contact Nos. 011-47185555, 47185504
Associated Business Computers
38 Todarmal Road, 2nd Floor
Near Bengali Market
NewDelhi 110001
Contact Nos. 91 11 23753300
Automation Systems
206, Rajouri Palace,
J-1/162, Rajouri Garden,
NewDelhi 110027
Contact Nos. 91 11 65462030
Axis Computech & Peripherals Pvt. Ltd
0 8, Lajpat Nagar-II,
New Delhi
NewDelhi 110024
Contact Nos. 91 11 29841249
C.I.Infotech (P) ltd.
K-33A
Green Park (Main) Basement
NewDelhi 110016
Contact Nos. 91 11 26962072
Delphi Marketing
13/5 ,
West Patel Nagar
NewDelhi 110008
Contact Nos. 91 11 25884816
Elite Business Machines Pvt. Ltd
F-207/3, Ashish Complex, New Rajdhani Enclave
Main VikasMarg
NewDelhi 110092
Contact Nos. 91 11 22504411
96-Nehru Place,
NewDelhi 110019
Ingram Micro
Punj Sons Complex , 2 Industrial Area
Maa Anandmai Marg , Kalkaji(Opp: Chandiwala Estate)
NewDelhi 110019
Contact Nos. 91 11 26239225
Hope this will be helpful. Thanks.
Jun 17, 2010 | HP LaserJet 3050 Printer
How to adjust the brightness on my sony vaio pcg-k17?
To adjust the brightness control, press Fn + F5 and release, plus the RIGHT ARROW or LEFT ARROW keys to increase or decrease the value.
On most notebook computers you can use the Fn+F5 keys to lower the screen brightness level, and the Fn+F6 keys to raise the screen brightness level.
May 18, 2010 | Sony VAIO K45 Notebook
How do i restore a medion laptop back to factory settings as we have the discs but we have a detachable cd/dvd disc drive. so really struggling to reset things
I will have to assume "detachable" means USB. You will need to enter the motherboard's BIOS setup program --- this is typically accomplished by pushing a key or keys as soon as possible after pushing the power button. Key DEL, F2 or F10 are most likely, but usually the system *tells* you ... look for something like "Press F2 to run setup".
Once you enter the BIOS setup program, look for "Advanced BIOS Features", which is usually the 2nd option in the left column (navigate using your arrow keys and press ENTER/RETURN to select). Using the arrow keys, move to "1st boot device" and select "USB" or "Removable Device". If you don't see either under "1st Boot Option", then *disable* all boot devices (1st boot device, 2nd boot device, etc.) but *enable* "Boot Other Device". This should force your motherboard to boot from the USB CDROM.
If your CDROM is *not* USB, then I'm afraid I've paddled up the wrong creek :-(
Hope this helps!
Apr 11, 2010 | Computers & Internet
I want to know the key code for pokemon stadium 1 and 2
DE000400 0000 Enable Code (Must Be On)
P1 1st Pokemon Codes
800AE562 03E7 Infinite HP
800AE580 00FF Infinite 1st Spell
800AE581 00FF Infinite 2nd Spell
800AE582 00FF Infinite 3rd Spell
800AE583 00FF Infinite 4th Spell
800AE584 0063 Level 99
810AE586 03E7 Max HP
P1 2nd Pokemon Codes
800AE5B6 03E7 Infinite HP
800AE5D4 00FF Infinite 1st Spell
800AE5D5 00FF Infinite 2nd Spell
800AE5D6 00FF Infinite 3rd Spell
800AE5D7 00FF Infinite 4th Spell
800AE5D8 0063 Level 99
810AE5DA 03E7 Max HP
P1 3rd Pokemon Codes
800AE60A 03E7 Infinite HP
800AE628 00FF Infinite 1st Spell
800AE629 00FF Infinite 2nd Spell
800AE62A 00FF Infinite 3rd Spell
800AE62B 00FF Infinite 4th Spell
800AE62C 0063 Level 99
810AE62E 03E7 Max HP
P2 1st Pokemon Codes
810AE65E 03E7 Infinite HP
800AE67C 00FF Infinite 1st Spell
800AE67D 00FF Infinite 2nd Spell
800AE67E 00FF Infinite 3rd Spell
800AE67F 00FF Infinite 4th Spell
800AE680 0063 Level 99
810AE682 03E7 Max HP
P2 2nd Pokemon Codes
810AE6B2 03E7 Infinite HP
800AE6D0 00FF Infinite 1st Spell
800AE6D1 00FF Infinite 2nd Spell
800AE6D2 00FF Infinite 3rd Spell
800AE6D3 00FF Infinite 4th Spell
800AE6D4 0063 Level 99
810AE6D6 03E7 Max HP
P2 3rd Pokemon Codes
810AE706 03E7 Infinite HP
800AE724 00FF Infinite 1st Spell
800AE725 00FF Infinite 2nd Spell
800AE726 00FF Infinite 3rd Spell
800AE727 00FF Infinite 4th Spell
800AE728 0063 Level 99
810AE72A 03E7 Max HP
Sep 27, 2009 | Nintendo 64 Console
Eidos Interactive Tomb Raider: Chronicles for Windows Logo
126 people viewed this question
Top Eidos Interactive Video Game Consoles & Games Experts
Hanzu
Michael Vincent Cruz
James Wishart
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
