Sim card is not getting detected in new galsxy s duos, the sim which is inserted 1st is only getting detected, i am unable to use other sim cards in it, the sim card are working fine with other mobiles, what could be the problem
It sounds like your samsung is locked to particular network.. You can remove this network restriction using unlock code.. you can purchase such code from any vendors online like
http://www.simpleunlocking.com/samsung-galaxy-s-duos/rs16wp9/
SOURCE: Samsung SIM card issues!
you dont have to buy new sim...go to your nearest service senter. hardware failure.... sim sockets or sim ic... thats the problem...
SOURCE: I have a T-mobile sim and I need to unlock my Samsung SGH-D407.
WOW! what a process! I don't know how you kept track of all that but , good job! Try this. It's a maybe, but better than nothing,
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
SOURCE: My Samsung SGH-t329 is not detecting any networks
That is because you will need to contact your current service provider to obtain the subsidy unlock code in order to use a different carrier's sim card or to use it internationally. The will provide it to you at no cost.
SOURCE: I have bought a Samsung
hi
check the sim card slot of your mobile. may be it get damaged . if so change the sim card slot.
this will fix the problem . and also format the phone .. this will fix the problem..
thank you
I think your sim is in problem.It is not sim lock or network lock problem.Please don't think like this.You can try inserting new sim card in the mobile phone and then if same problem occurs you can visit nearest service store and check sim card slot.They will fix it.Good Luck Dear.Have a nice and great Day dear.By Raising blogstar.
