Backfires through exaust,wont idle,all new top end,new reeds, new carb rebuild, fmf fatty pipe,repacked d,g, silencer,got good spark! changed possition on needle valve,nothing! changed to 260 main jet,nothing! turned idle screw to compensate...nothing! same with tors unit!!! need help!!!!!!!!!!!!!!! [email protected] or 330 469 9678
Hi there . These brothers know what to do. Trust me i feel your pain. http://www.blasterforum.com
jo
SOURCE: i have a 1999 yz250
Hello Rick...Try backing the idle air screw out another half to 3/4 turn. The mid range stutter on these bikes is usually from the interface between the needle and the brass bushing just above the main jet. Also check your reeds, a chipped reed will cause the same problem. Clean all the carbon and gunk out of the expansion chamber. If it's real bad you may have to use a torch. Make sure your air filter is clean.
A 165 main jet will give you better response with a 40:1 mix, specially if the plugs are fouling.
..You can also go up a heat range on your plug... I hope this helps.
