Question about Samsung YP-K5 MP3 Player
Samsung K5 trouble shooting
Heyy my Samsung K5 won't turn on. It was chargin fine this mornin, aftger it completed charging I took it off and i tried turning it on but nothing happens. I slide the button hol it and nothing still happens. Then i tried reseting it and nothing happens. my player is on hold and it is not working even after pressing the hold button plz solve this
I'm not sure this is the same problem but my k5 wouldn't turn on either. My solution was to charge it in the computer while its off, or an xbox.
Posted on Jun 09, 2009
  • 4 Answers
Just a question, is there a button that has to be in a certain position while charging? I had a similar problem with my daughters ipod of a different company. I am not sure if this will help or not. I hope it does.
Posted on May 26, 2009
I replaced my battery this week on my 99 Yukon. Truck started fine for several days. Now it won't turn over, at all. All the equipment inside works, so the battery is not dead - it just wont ever try...
Check for power at the small wire at the starter with the key inthe crank position. If there is power than the starter is bad or the connections at the battery are not good. If there is no power put the trans in neutral and check for power again. If there is still no power let me know and I will get you some more info on trouble shooting the ignition switch and the PRNDL switch.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
May 23, 2011 | 1999 GMC Yukon
The mp3 player wont charge. plug into computer and it shows charging but as soon as it is disconnected it shuts off and wont turn on.
Some mp3's don't expressly charge on the computer, that why when you connect it, the computer only sees it as a flash but is not actually charging it all this while and the battery is completely down. So try and get an external charger for it, the battery may be completely dead.Or probably you need to change the battery. Hope that puts a smile on your face.
Feb 04, 2010 | Samsung YP-K5 MP3 Player
Samsung yp-k5 battery
hi i have the same problem i have done everything tried everything
Mar 11, 2009 | Samsung YP-S5JAB MP3 Player
Samsung yp-k5 MP3 not turning on
I reset my mp3..well actually my mum did :)
Nov 07, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-K5 won't work
Get the latest firmware upgrade from Samsung website, or call 1-800-SAMSUNG
Jul 06, 2008 | Samsung YP-K5JAB MP3 Player
Won`t charge
I had the same problem. First disconnect the mp3 player from your computer. Then go into the control panel, select the system icon, go to the device manager tab, and then find the Samsung K5 driver. Right click on it and select uninstall. Now reconnect your mp3 player. That should do the trick. Somehow the driver file got corrupted and wasn't letting the k5 charge.
Jul 02, 2008 | Samsung YP-K5 MP3 Player
Samsung p2 won't turn on
HEYY. okay. mine did the exact same thing but i took a toothpick and pressed the "reset" button on the back of the player. after i hit it once or twice, i tried turning it on and it worked.
Mar 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Broke
before i had the same problem, when i thought my k5 runs out of battery i plug it in to charge, but it said charge complete and when i unplug it, it still wont turn on. but then i tried switching to a different usb plug on my computer and it worked. so i guess the problem is that some of your usb slot on your computer isnt working properly, try using a different slot.
Jan 20, 2008 | Samsung YP-K5 MP3 Player
i had a different problem before... mine turned on, but lagged with the "Samsung" logo for more than 5 minutes. Then I pushed the Reset button at the back, and it turned off. When I tried to open it again, it just lagged once more. I then realized that I recently put a playlist I made with Windows Media Player, which turned out to make it NOT work (and probably caused the lag for some reason), so I deleted the playlist, and it wwnt back to normal again. What a relief.
I just shared this for future uses. xD
Oct 27, 2007 | Samsung YP-K5 MP3 Player
Samsung YP-K5 MP3 Player Logo
134 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
