Question about Troy-Bilt Garden
Tiller will not keep running
My Troy built tiller (Hourse) will start, run for a couple seconds and quit. What do I need to do to keep it running. I have spraded carberater cleaner in the carberator, changed the spark plug, drained the old gas put in new.
  • katn90 May 26, 2009
    It acts the same with choke on or off.
  • Dwain Pippen May 11, 2010
    It starts on choke then dies while still on choke or after you take it off choke?
  • 376 Answers
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
Posted on May 26, 2009
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I just purchased a 2011 big red troy built tiller and used it the first time today and it just starts acting like it is not getting gas and starts sputtering and dies
problem with a lot of small engines no running right is the gas we have to use these days (ethonal) they were not made to use that gas
Mar 12, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy Built 6.0 HP stored for winter. Fired up and
Most definitely. You aren't getting enough gas, probably because the float valve is gummed up. Drain the gas, put in a little carb cleaner and a little fresh gas. Fire it up. Do that a couple of time if needed, then fill tank with fresh gas. Use a gas stabilizer like Sea Foam to prevent this.
Apr 05, 2010 | Troy-Bilt Pony Garden Tiller
Troy built tiller starts chugs along and then kills full size mod
I'm sorry you are having trouble with your Troy-Bilt Tiller. I have a genuine Troy-Bilt and I miss the original manufacturer and the help they provided me with my 30 year old machine.
I believe your trouble is in the needle valve adjustment. If you check the bottom of the carb, you will find the needle valve. It should be open about 1 1/2 turns and then fine tuned open or closed a bit to get the best speed. There is the possibility that your carb is dirty inside and could benefit from some carb or injector cleaner. You may also benefit from installing a new spark plug as well. Sometimes, in older engines, you can benefit from using a spark plug one or two heat ranges higher. You will have to experiment with these options to find the best for your situation.
I hope you find these suggestions to be of some benefit.
Thank you for posting your question on FixYa.com
a
Nov 07, 2009 | Troy-Bilt Pony Garden Tiller
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Jun 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
LOOKING FOR A MANUAL FOR A TROY BUILT TILLER MODLE 1003W
Tiller runes for and about and hr then it stops but it will start up when you pull the rope and and it
will run. You go to till and it will stop it has a new air filter and spark plug in it.
What is next.
Dave.
4 / 11 / 09
9 ; 51 / A / M
Apr 09, 2009 | Troy-Bilt Garden
Garden Logo
607 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
