Question about Maytag Performa PAV2200
Maytag Performa is siezing up
I put a load in tonight and it started making a rough sound.  First thing that comes to mind is that it sounded like a bearing, but I'm no expert. Proven by what I did next...
I let it keep running. Thinking maybe it just had something that was in it and it would work itself out.  I know, bad idea. Well, almost half way though the spin cycle I heard it come to a halt and start a high pitch whistle sound. I immediatley turned it off. Thinking the worst I waited a couple minutes and turned it back on just for a split second to make sure it didn't lock up. It started to turn with the same growling sound so I switched it off.
Can anyone give me an idea of what it might be and if I could fix it myself?
Thank you!
  • 1 more comment
  • bowyorang Oct 24, 2007
    Thanks Mike!
    I checked it out and it looks like the pulley underneath the water pump is fried! It had some kind of metal sleeve inbetween the pulley and pump that looks chewed up. It also looks like the pulley on the motor kept turning while the pump locked the belt up and chared the inside of the motor pulley with belt material.
    I have ordered a new pump assembly and motor pulley that will hopefully be here by the end of the week and I'll let you know what happens!
    Thanks again for your help!
    Micah
  • ron1948 Nov 13, 2007
    How do you remove the pulleys and the belt?
    I failed to mention that mine is PAV2000AWW.
  • 290 Answers
You should be able to find out what it is easily enough. Unplug the machine and slide it out enough to be able to tip it back so that you can get to the belt and pulleys underneath. Remove the belt and turn the water pump and transmission pulleys by hand. Be sure to turn the transmission pully both directions.(it is the large one) The most likely thing you will find is a problem with the water pump. It could just have something in it that you can clean out or it may need replacing. Post back with what you find out and I will try to help you decide if it is something you can repair yourself.
Posted on Oct 21, 2007
  • Michael  Lindley
    Michael Lindley Oct 23, 2007
    Just wanted to follow up on your washer and see if you need further assistance.
    Thanks/Mike
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Maytag performa pav3200 washing mach. very load shrill noise during spin
if you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
Jan 06, 2013 | Maytag Performa PAV3200
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Maytag > Performa > Drains,Rotates, Fills but wont spin
I had the same problem with you a couple days ago. I disassambled the whole machine and i found out that the belt worn out and the motor also losen so i am looking for parts to replace.
Sep 05, 2008 | Maytag Performa PAV2200
Maytag performa dryer
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Washing Machines Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
