Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Flashing tv screen that looks like a strobe light
    Problem Solver:
  • 7 Answers
............................no clue
Posted on May 26, 2009
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Vizio screen flashing
ok when mine did that i shut it off then on then off then on again four times then unpluged it and plugged it back in and waited for a few minutes and it was fine if that don't work then its most likely an internal problem and it would have to be fixed by a professional
Feb 05, 2014 | Televison & Video
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
My Vizio VX42L is flashing like a strobe light.
Mine did the same thing. Remove the stand and back of the tv. Be careful with screen do not lay on hard surface and scratch. When you take the back off you will see a board on the left side and a board on the right side. They are labeled slave and master. Remove the ribbon cables and take board out. There are 2 capacitors on each board (about an inch long). These are probably all bad (ends bulged a little with black stuff on bulged end). Radio shack has them for less than $2.00 each. turn the board over and you can read the size of the capacitor. You need someone who can use solder wick and remove all four capacitors and solder in new ones. Notice how the capacitors are turned. Each one is labeled with a dash for negative. Make sure you bend new capacitor connectors the same and put back in the same way. Put the boards back in the tv and attach all ribbon cables. Put back and stand on. hook up your power and cable box and you are ready to watch tv with no more strobe. Me, my husband, and son did ours last week. I looked up the problem on the internet, husband removed stand & back, son with the steady hand did the soldering. Family project that went well for once.
Jun 12, 2010 | Vizio VX42L 42 in. LCD TV
Canon 580ex II strobe issue
This depends on the mode you have selected on the flash gun. If you have Multi selected you will get the strobe effect. The strobe effect is all so present to help the flash set the correct exposure. It's not a problem with the flash or the camera. Spend some time reading through the flash gun manual. I have to admit it is not always clear. Also try Youtube for a video.
Sep 21, 2017 | Canon Speedlite 580EX II TTL Flash
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
My vizio tv flashes like a strobe light
Sounds like your Backlight Inverter Board is going out, saw one on ebay for about $55 : ) have to get the one for your model tho...
Aug 21, 2009 | Vizio L32 32 in. LCD HDTV
Screen flahes after tv's been on for 20 minutes
HP sold these TV's with a KNOWN problem. As consumers we are taking action. Contact Us: dorje@forexcafe.org
Apr 06, 2009 | HP PL4260N 42 in. Plasma HDTV
I cant use dsc h1 with strobe light
If you problem is that the double flash triggers the strobes early (on the first flash and the shot is made on the second flash - dark) you either:
1. Get a wire accessory to command the strobes
2. Put a simple external flash on top of the camera and use it to trigger strobes. If you don't need the light from this flash just point it up of backwards, it will still trigger the strobes. If it does not rotate, you can use tin foil. A very simple external flash will do, as the camera will flash only once with external flash.
Jan 09, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
Jun 19, 2007 | Canon SPEEDLITE 580EX TTL Flash
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
134 people viewed this question
Jerry Greenberg
Jerry Greenberg
