Question about Toshiba Satellite U205S5067 Notebook
How to replace mini wireless card on Satellite U205 S5067 laptop problem: The original card is an Intel 4965A/B/G; I want to relace it with an Intel A/G/N mini wireless card. I want to know the follow
How to replace mini wireless card on Satellite U205 S5067 laptop problem: The original card is an Intel 4965A/B/G; I want to relace it with an Intel A/G/N mini wireless card. I want to know the following: 1) How to access the wireless card on my laptop 2) Will the 4965A/G/N be compatible and will it work
  • Art Ellison
    Art Ellison May 11, 2010
    The wireless card should be accessible from the bottom of the case. Undo the little panels you see there and see if you can access it.
    As for compatibility, when you get the old card out, look at the connector (the card has an edge with metal strips on it, probably).
    Of course, you'll need drivers for the replacement card.
    Did the old card quit? Have you looked on a Toshiba site or forum to ask this question?
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Hope this helps.
Apr 05, 2011 | Computers & Internet
Need drivers for wireless mini lan card for Toshiba Satellite 1900-704
http://www.downloadatoz.com/driver/download_124691,toshiba-satellite-m35x-s3491-intel-802-11b-g-mini-pci-wifi-driver-8-0-12-9000w2.html
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed.
rate this solution please
Nov 24, 2010 | Intel Toshiba Satellite Mini-PCI Laptop...
How to replace the built in wireless
This step by step disassembly guide with photos will help you perform your replacement.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-U205-U200/disassemble-laptop-1.htm
Best Regards,
Marcus
Sep 15, 2010 | Toshiba Satellite U205-S5034 Notebook
The backlight just quit working on my Toshiba Laptop
The backlight problem can be caused by a faulty inverter or a faulty/worn out CCFL lamp.
These parts are available from the Internet. I found LCD Parts a good company to deal with. Check them out for parts,service and DIY info.
Use this link :-
www.lcdparts.net
Sep 14, 2009 | Battery Technology for Toshiba Satellite...
How to remove the intel3945abg wireless mini-pci-e card of toshiba satellite u205
Mini pci-e cards can be removed by clicking the card towards the case. The card will then pop out so you can remove it.
Jul 06, 2009 | Toshiba Satellite U205 Notebook
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
241 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
