Question about Haier HTQ21JAAWW Top Freezer Refrigerator
Water on floor coming from fridge
There is water on floor in front of fridge that is coming from fridge.
    Problem Solver:
  • 6 Answers
I would call a plumber
it may be a big issue
Posted on May 26, 2009
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
  • 20 Answers
SOURCE: small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
Posted on May 23, 2009
  • 32 Answers
SOURCE: water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Posted on Sep 07, 2009
  • 60 Answers
SOURCE: water is coming out on the floor in front of the
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I you should pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
Posted on May 01, 2010
rickead1
  • 1998 Answers
SOURCE: maytag fridge --daily drops water
First thing you have to do is figure where is the water coming from? Do you have a worn or bad seal on the lower door of the unit if you did this would cause the unit to leak water out by makeing condensation form along the bottom of the door. If the seals are not worn and you had water going to the door you would then check the bottom of the door where the water line goes into the door to go up through the door to the dispenser. You did not state that you do have a water dispenser on your door therefor I would assume this issue to be happening due to a worn seal on the unit. If you have any further questions message me back and if you need me to look up the seal for that unit and provide the part number message me back the model number of the unit as well Thanks Rick
Posted on Jun 29, 2011
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water on floor under front of fridge
Sep 07, 2009 | Refrigerators
What may cause the outside copper lines to freeze ,the refrigerato is cooling but i notice water comes out from underneath at the floor.
This is normal if the weather has been hot and humid. There is a "drip tray" that can be pulled out from underneath the front of the fridge if its full the water will poor on to floor. If the fridge is running all the time check your door seals and make sure the door closing properly as this will also cause the same problem.
Fridge 102H, R600a now about 12 yrs old leaks water onto floor. I have checked the outlet pipe from the fridge and the receiving dish. The pipe is clear. The receiving dish has water in it although it...
The pan will continue to have water in it. The defrost system water drips in the pan where it is evaporated by the condenser fan blowing on it.
Does this pan overflow? Is the water on the floor coming from this pan? Or could it be coming from the water inlet valve where the water supply comes in? Does the water come out the freezer or fridge door at the bottom?
Aug 25, 2009 | Refrigerators
Lickage of water from frost free fridge
actually a frost free fridge should leak water but it should not make it to your floor. every frost free fridge goes into defrost every 8 hours for 15 minutes where it will melt the ice off the coils. there is a pan underneath the fridge to catch this water. it should evaporate before the next defrost cycle there is not much water that comes out. you may want to pull the front cover and look under the fridge make sure the pan is in place and there is not a crack in it
Apr 27, 2009 | Refrigerators
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Haier HTQ21JAAWW Top Freezer Refrigerator Logo
223 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
