Question about Fujitsu AMILO D-7820 Notebook
Need to turn wireless on - Fujitsu AMILO D-7820 Notebook
    Sergeant:
  • 199 Answers
Check on the front there should be a sliding button with a little light slide it to on position
Posted on May 26, 2009
Where is the wireless radio switch
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 05, 2012 | HP Computers & Internet
It will not connect to wireless, it keeps saying turn on wireless communication switch yet there is no switch on the computer. I have been without a computer for almost a week, please help!
@kblossom1280
There's two switch to turn the wireless capability of this laptop:
1. You need to turn ON the physical wireless switch located at the top of the keyboard (see image below)
2 If that doesn't turn the Wireless ON, you need to press the Fn+F8 key (the Fn key is located on the left side of the space bar).
Good luck.
Sep 07, 2011 | Toshiba 14 Satellite M645S4114 Notebook PC
Dell inspiron 6400 wireless capability turned off. need to find switch or function key combination
Hi, How do u do? You can easily turn it on by pressing Fn + F2.
have nice day. Babak
Mar 13, 2011 | Computers & Internet
Recently downgraded to windows xp from vista, Atheros wireless will not turn on automaticcal when computer is restarted. At the windows loading screen, the wireless light turns blue for 3 seconds and then...
I had this problem too. You need the HP Wireless Assistant. Download it here- ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36770.exe
Once installed, open the HP Wireless Assistant and click Properties button. Check the box next to "Independent controls for installed wireless devices." Then click "Turn All On" button. On next boot it will be enabled!
Sep 07, 2010 | HP Computers & Internet
Data connection refused
After cancelling the data plan with the wireless service provider, the message Data connection refused appears at the top of the Home screen on the BlackBerry smartphone instead of the branding of the wireless service provider.
This is caused may be you were previously subscribed to a data plan through a wireless service provider, and the BlackBerry smartphone is still configured to attempt to access the data network.
To resolve this issue, you need to turn off the Data Services feature on the BlackBerry smartphone. To perform this, you need to complete the following steps:
  1. From the Home screen, open the Options menu.
  2. Click on Mobile Network or Network.
  3. Set the value of the Data Services field to Off.
  4. Open the menu and select Save.
  5. Return to the Home screen.
  6. Turn the wireless transceiver off and then on again.
To enable (turn on) the wireless transceiver on the BlackBerry device, go to the Home screen and select the Turn Wireless On icon or open Manage Connections and select the wireless connection to be enabled. Once enabled, the icon will display Turn Wireless Off .
To disable (turn off) the wireless transceiver, go to the Home screen and select the Turn Wireless Off icon or open Manage Connections and select the wireless connect to be disabled. Once disabled, the icon will display Turn Wireless On.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
I need a wireless driver for my 2wire1800hg for a gateway
I don't think you need a wireless driver. Instead inter http://home/ at the top of your Internet browser ( adress bar ). Press the Enter key on your keyboard. On the new screen click on the Home Network tab. On the that new screen look under Status at a Glance. Look to the right of the word Wireless. If it says ENABLE, it wants you to click on it to turn on the wireless feature of your modem. When you ckick on ENABLE, it turns on wireless like turning on a light bulb with a wall switch. That ENABLE button will change to DISABLE incase you want to turn it off latter.
Sep 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Intel PRO/Wireless is turned off and I need help turning it on.
just go to Network Connection >>right click Wireless Adapte>>Enable.
if doesn't work try to uninstall the Wireless NIC from the Device Manager, go to Device Manager>>Network Adapter(expand)>>Right click on wireless adapter>>uninstall.
once done, click on Action Menu on the top and click on Scan for hardware changes. It would automatically detect the wireless card.
then try to use it, it should work fine :)
Regards,
Askari
letter4askari@hotmail.com
Mar 25, 2009 | Dell Latitude D600 Notebook
Wireless radio disabled
If you have a laptop and it has built in wireless adapter, it may have a switch or a button that you need to switch on in to turn on the wireless connection radio. Usually, it can be found on the sides or on the front panel of the laptop. On other laptops, you will need to hit some combination of keys on the laptop's keyboard to turn on the wireless connection radio, for example, Fn+F5. Please refer to the manual of your laptop for reference on how to turn on or enable its wireless radio.
By the way, what is the model of your laptop?
Sep 18, 2008 | 2wire 2700HG-B Router (2700HGB)
How to get hp wireless assistance
If you need to find the Wireless Utility to scan for available networks, it should be in Start > Programs under HP Wireless
If you need to turn your wireless adapter on:
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections
Click window opens. Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | HP Computers & Internet
Fujitsu AMILO D-7820 Notebook Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
