Question about Vacuums
Lubrication for powerhead motor
I have an old ap 200 canister type electrolux with power head. The motor on the power head does not turn freely, it overheats and shuts off. I frequently have to use the reset button after letting the motor cool. Does the motor require any kind of lubrication? Do any other parts of the power head require lubrication like the beater bar itself? Thanks for your help, Bryon
    Problem Solver:
  • 9 Answers
The power head motor dose need service first thing you should do is take the top cover off by removing the screws on the bottom of power head then remove brushtroll clean brushroll and the end bearings make sure they spin freely squirt some lube (wd40n or tri flow) on the end cap bearings . Then clean motor by blowing it out with compressed air lube bearings with either wd40 or tri flow that should free up the motor and brushroll
Posted on May 26, 2009
I have an old AP 200 Electrolux Canister Vacuum cleaner. Can,t figure out how to take it apart to check the main switch & motor. What is the trick to getting it apart?
The whole thing comes apart like a puzzle. The side rubber pieces on each side slide outward to front of machine. After they are removed everything comes apart. Make diagrams so you will not forget how to put back together. If you need any more help, let me know. GOOD LUCK FRIEND.
Sep 12, 2014 | Electrolux Vacuums
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Jul 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Jun 26, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux power nozzle not working
the powerhead gets its power through a connector adjacent to the hose connection to the vacuum end. there's two wires embedded in the hose which make its way to the handle, pipe and powerhead. take apart the handle and see if you can read continuity from one end to the handle switch.
Aug 06, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
180 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
