Question about Eemax Instant Water Heater 120V SP3512
Eemax SP3512 not works intermintently, more off than on.
Has been working up until a couple months ago.  Hooked up to 3 different sinks.  All 3 worked at one time, now only the closest one will trip it on and only for a few seconds and then it shuts off.
  • 332 Answers
You have a clogged filter turn off the water on the unit on both sides, right below the unit there are 2 caps one on each side take the cap off there is a filter in side, clean it and reistall it that should take care of the problem, you might want to flush out the system while your doing this also
Posted on May 29, 2009
Fuse for eemax water heater 24027
http://eemaxtankless.com/wp-content/uploads/2015/10/Eemax-Lowes-Manual-FINAL.pdf You should have an electrician install breakers (3) and wire unit. the unit is113 amps max draw. This is not a homeowner istallation.
Sep 24, 2017 | Eemax Water Heaters
How do you adjust the temperature on a model SP 3512
Check if thers incoming water. Ur heater dependent on the level of water
Sep 15, 2014 | Eemax Instant Water Heater 120V SP3512
Heating element keeps going out
Make sure the water fittings on the top of the water heater are not two dissimilar metals...this causes electrolysis. If you do, you need a dielectric union to connect the two metals ie copper & galvanized steel
Dec 02, 2013 | Eemax Heating Element 240 Volt 9500 Watt
No water coming out from outlet.
What product? eemax sp2412/
http://www.homedepot.com/catalog/pdfimages/e2/e289142e-792b-48ed-9b6a-bae87550a046.pdf
Is this new installation or older installtion that worked before?
Have you cleaned the inlet water filter?
Hs unit exposed to hard water?
Has unit been delimed before?
Have you disconnected supply line under sink to see if problem is faucet?
Gene
h
Aug 31, 2013 | Eemax SP2412 2.4kW 120V
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Oct 05, 2010 | Eemax EX380T2T2 Series 4 Whole House...
The center heating element is no working. How much does a replacement element cost?
the price will vary in different localities.
you should call a plumbing wholsaler in your area. Home depot and Lowes will not carry these, neither will you local hardware store.
the replacement is faily simple. Eemax is a nice heater, although faily expensive to opperate.
Aug 20, 2010 | Eemax EX280T2T Series 3 Whole House...
Trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Feb 03, 2010 | Eemax SP80 8.0kW 277V
Water is spraying out of the drain area of my sink
waste grate will have to be re-bedded with plumbers mait compound not a big job best of luck
Oct 16, 2009 | Eemax SP3012 Single Point Electric...
Seven months ago, a bosch alled at my house
you will always have this problem in city type of appltcations.there is too much of a flow differation.
Jul 13, 2009 | Bosch 2700ES Natural Gas AquaStar ...
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
Eemax Instant Water Heater 120V SP3512 Logo
391 people viewed this question
Top Eemax Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
