Question about Goodman Heating & Cooling
Everything turns on for my refrigerated unit, but no air blows.
Everything turns on but no air blows out
    Problem Solver:
  • 7 Answers
I would have to guess that the fan is not working, which could mean that the fan is bad, or that there is a bad fuse. Also, it could be in the control panel that turns on the fan. If you know anything about wiring. Try hard wiring the fan and see if it actually works. If it does, then you would move on to checking the control panel.
Posted on May 26, 2009
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
My g.e. a/c isn't blowing as hard as it should its running the same temp on fan and cool its not cold what should i do we cleaned the filter and everything plz help me
Hello my name is Heath it will be my pleasure to assist you. The first thing to check is the filter in the furnace or air handler. Also check the inside coil to be sure its not frozen up. Does the air coming out feel cold? It sounds like the unit could be low on charge which means it has a leak and should be leak checked repaired and properly charged. You would need refrigeration gauges to put on the system in order to properly check the refrigerant charge in the system. One other thing could be a dirty condenser coil. Turn the power off to the unit and use a garden hose with a strong nozzle and spray water through the whole coil to try and blow any dirt or debris through the condenser coil in the outside unit.
Aug 27, 2011 | Kenmore 72055 Air Conditioner
This is a wall unit and it works, but it does not blow cool air it blows air like a fan. That is the only issue I detect. sounds fine.
Make sure that the temperature SP is low so that the compressor should run. If everything that should work appears to be working except for the actual cooling part, then perhaps you had a refrigerant leak. Could you open up the unit and check the refrigerant pipe connections to see if there's anything that look like corrosion.
Jul 19, 2011 | Fedders A1A10W2B Air Conditioner
Does not blow cold or hot air
Haved you cleaned the filter?? Clean them! It might be out of refrigerant. Have the unit professionally checked.
I take the time to help, so please rate me!
May 30, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
I have a floor model airconitioner and it has been running constantly for 4 years...now it will not cool ..what is happening
If everything is working on the AC unit and the only problem is that not blowing cold air and instead the air is warm or regular temperature then your problem might be that you need to what is call recharge your unit with refrigerant. this is a common problem that can be solve easy by just adding more refrigerant to the unit
Sep 24, 2009 | Heating & Cooling
Maytag MSD2651HEQ frige not cooling; can hear/feel fan blowing
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Maytag MSD2651 HE Side by Side...
Freezer blowing cool air, but not freezing.
Hello there:
first make sure that the back of the unit is clear of any dirt or obstructions
also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Refrig does not blow clod air....only room temp air
sounds like the gas in the unit needs recharged, probably cost about £30-£50. usually 10 minutes work
Jan 24, 2009 | Whirlpool Refrigerators
Refrig cooling
check make sure all the fans are blowing one in freezer, one by compressor... should all be running when frig. is running
Aug 30, 2007 | Refrigerators
Heating & Cooling Logo
71 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
