Question about Tiny Computers B1996 19" CRT Monitor
Bios access on a tiny
I need to know the key press to enter bios/setup on a old tiny ti440bxm
  • 3 Answers
Its a Tiny T1440bxm not ti440bxm and you press the delete key on initial boot
Posted on Feb 27, 2011
  • Mbwar7470 Mar 06, 2011
    Tap on the Delete key prior to the Tiny.com flash screen
  • 700 Answers
Ok sometimes when I do not know exactly what is the exact key to hit to get to bios setting. You can do this procedure.
After POST quickly hit the button PAUSE or after pressing On button hit PAUSE then ENTER until you seen the list of button to be hit to get into bios setting.
Normally it will flag some Button to be hit like hit ESC = to go to bios setting, F1 = for help and others. if you doesnt catch it up reboot it again.
Hope it helps. Goodluck
Posted on May 26, 2009
Hp8470 how to enter in bios
You asked this in the Mac Laptops area.
However,
To access the BIOS Setup, turn on the computer and repeatedly press the esc key to enter the Startup Menu, and then press the F10 key to enter the BIOS setup utility.
Figure 1: Example - BIOS Setup Utility
c02258786.gifThe BIOS Setup window consists of options for Security, System Configuration, and Diagnostics.
All the best to you,
Kerry
May 27, 2014 | Computers & Internet
Bios fw140e reset vgn vergine
Follow these steps to access the BIOS on a VAIO computer.
WARNING: Other than resetting the BIOS to the default values, making changes to the BIOS is an advanced procedure that can produce unintended results if not done properly. For instance, if you set a Machine Password and later forget that password, it will require advanced technical support and possibly service to regain access to the computer.
  1. Turn off the computer.IMPORTANT: If you are having difficulty accessing the BIOS, or are doing so as a step in troubleshooting an issue, it is recommended that you remove all media or any peripheral devices connected to the computer before trying to access the BIOS.
  2. Restart the computer.
  3. At the black VAIO logo screen, press the F2 key.
If you are accessing the BIOS as a step in troubleshooting an issue, you may need to reset the BIOS to the default settings. While the exact steps will vary slightly based on the version of the BIOS installed on the computer, these general steps will allow you to reset the BIOS to the factory default values:
  1. In the Setup Utility window, use the arrow key to select Exit.
  2. At the Exit screen, press the down arrow key to select Get Default Values, and then press the Enter key.
  3. At the Get Default Values prompt, use the arrow keys to select Yes, and then press the Enter key.
  4. At the Exit screen, with Exit Setup selected, press the Enter key.
  5. At the Exit prompt, use the arrow keys to select Yes, and then press the Enter key.
  6. The computer will restart.
Reference: How to reset the BIOS to the default settings
Oct 24, 2013 | Sony VAIO VGN-FW140E/W Laptop
Power but no display
try going into bios blue screen press f2 or f10 or f12 on start up beep . change setting in video settings
  1. Watch for a "entering setup" message in the first few seconds after turning on your computer. This message varies greatly from computer to computer and also includes the key or keys you need to press to enter BIOS.
    Here are some common ways you might see this BIOS access message:
    • Press [key] to enter setup
    • Setup: [key]
    • Enter BIOS by pressing [key]
    • Press [key] to enter BIOS setup
    • Press [key] to access BIOS
    • Press [key] to access system configuration
  2. Quickly press the key or keys instructed by the previous message to get into BIOS
Oct 22, 2013 | Biostar Computers & Internet
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
Dec 23, 2012 | Lenovo IdeaPad Z560 Notebook
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
Regards,
joecoolsvette
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Computers & Internet
In bios how do you access settings in intelligent tweaker
To access the BIOS Setup program, press the <Delete> key during the POST when the power is turned
on. To see more advanced BIOS Setup menu options, you can press <Ctrl> + <F1> in the main menu
of the BIOS Setup program.
Once in the MIT menu CTRL+F1 should show you more advanced options also.
Mar 22, 2012 | Gigabyte GA-G31M-ES2L Motherboard
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
Entering bios setup
Occasionally, most computer owners will need to access BIOS on their computers in order to change or update the computer's most basic operations; such as memory and boot order.
Different computer manufacturers will have you press different buttons to access BIOS depending on the model you have. For example, on my laptop, I press F12 to enter the BIOS setup utility.
Here's how to figure out how to enter your computers BIOS setup utility. 1
Turn your computer on or shut it down and restart it if it is already on.
  • Step 2 As soon as the computer starts up, watch for a message that informs you about which button you will need to push in order to enter setup, aka BIOS.
  • Step 3 The opportunity to press the correct key to enter BIOS passes by quickly, so you need to find that key and press it before the computer moves on to the next stage of booting. If you miss your chance, just restart the computer and try again.
    You can always access BIOS, even on computers that dont have an operating system installed. This is because BIOS is part of your computer's motherboard hardware and has nothing to do with Windows, Linux or whatever operating system you may be using.
  • Dec 02, 2009 | Alienware PC Systems M7700 Notebook
    Toshiba Satellite 1400
    To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
    Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
    • Press Del or F2 immediately after powering on.
    • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
    • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
    Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
    • Press F10 while the cursor in the top right corner of the screen is blinking.
    • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
    Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
    • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
    • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
    • Older Dell laptops may use Fn+Esc or Fn+F1.
    eMachines - eMonster, eTower, eOne, S-Series, T-Series
    • Press Tab or Del while the eMachine logo displays on screen.
    • Other eMachine computers may use F2 to enter BIOS.
    Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
    • Press F2 once the Fujitsu logo appears.
    Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
    • Press the F1 key repeatedly after restarting the computer.
    • Some older Gateway computers use F2 to access the BIOS Setup utility.
    Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
    • Press the F1 key after restarting the computer.
    • HP Tablet PCs may use F10 or F12.
    • Other HP computers may allow access to BIOS using the F2 or Esc keys.
    IBM - PC, XT, AT
    • Press F1 immediately after powering on the computer.
    • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
    Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
    • Press F1 or F2 after powering on the computer.
    • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
    Micron (MPC Computers) - ClientPro, TransPort
    • Press F1, F2 or Del immediately after powering on the PC.
    NEC - PowerMate, Versa, W-Series
    • Press F2 to enter the BIOS Setup.
    Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
    • Press F1, F2, or Del to enter BIOS.
    Sharp - Notebook Laptops, Actius UltraLite
    • Press F2 after the computer starts.
    • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
    Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
    • Press F2 or Del on startup.
    Sony - VAIO, PCG-Series, VGN-Series
    • Press F1, F2 or F3 after turning on the computer.
    Toshiba - Portégé, Satellite, Tecra
    • Press F1 or Esc after powering on to access BIOS.
    The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
    ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
    Cybermax - Press the Esc key.
    Tandon - Press the Ctrl+Shift+Esc keys.
    Good Luck and Hope it helps...
    http://www.wnycomputerpro.com
    Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
    Tiny Computers B1996 19" CRT Monitor Logo
    950 people viewed this question
    Top Tiny Computers Computers & Internet Experts
    David Payne
    David Payne
    Are you a Tiny Computers Computer and Internet Expert? Answer questions, earn points and help others
