Question about Toshiba Lands Phones
Program and use speed dial numbers
We are trying to program telephone numbers into our speeddial for the EKT6520-sd phone systems
  • 38 Answers
Speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
Posted on May 31, 2009
Speeddial numbers
Select menu >phone book -contacts> take options and scroll down to speed dial >select number from the phone book to be assigned from the speed dial as it will assign automatically from 2 to 9 or as you want to select and asssign
Jun 29, 2012 | NEC Ip2at-12txd Phone/telephone Handset...
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
How to set speed dial on panasonic kx-t7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
Address storage
Mar 07, 2010 | Panasonic KX-T7730 Corded Phone
CANNOT ENTER NUMBER INTO AUTODIAL.
Feb 03, 2010 | Panasonic KX-T7730 Corded Phone
Speed dailing
Nov 12, 2009 | Panasonic KX-T7730 Corded Phone
How do i program a system speed dial?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Oct 07, 2009 | Panasonic KX-T7730 Corded Phone
I don't know how to store spped dial numbers. I have 10 numbers to be stored to the Panasonic KX-T7730. Unfortunately the described way as per the users' manunal didn't work. Please help
If you are using the KX-T7730 phone on a Panasonic 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate / vote this answer if it was helpful.
Thank you.
Oct 05, 2009 | Panasonic KX-T7730 Corded Phone
I have a panasonic KX-T7300 and want to assign new speed dial numbers. I have the manual but it doesn't show how to do this please help.
Thank you.
Oct 01, 2009 | Panasonic KX-T7730 Corded Phone
I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Thank you.
Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
2,079 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
