Question about Leapster Learning System
Touch screen and stylus pen not working
When following the instructions for recalibrating the stylus pen, my leapster had no crosshairs appearing on the screen to help calibrate the pen. Anyone else have this same problem? Same problem as above.
I just had the same problem and found a solution on another thread on this site. Clean the screen really well with Windex and dry it. Check all 4 edges for crumbs that might be lodged in there. I found one tiny crumb. I dislodged with a small nail file (gently!), wiped the screen off and then it worked! I didn't even bother recalibrating it. When I turned it on and went to the sign in screen, it was working fine. The original post also said to try "milking" the screen in case pressure had caused it to stick. Press gently with your thumb on the screen in various spots around the screen, then try again.
Posted on Nov 30, 2009
Capnsven - thank you so much! My daughter has only had her Leapster 2 for about a month now and it stopped working! It would start up and get to the sign in screen and then it wouldn't do anything. I cleaned the screen really well and found ONE little crumb stuck in the side of the screen, got it out and it works now! Thank you thank you! I almost went and bought a new one!
Posted on Feb 11, 2010
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
I recalibrated the leapster2. It recognizes the stylus on the calibration screen. When I reboot it still doesn't recognize the stylus at all. Please help.
If your Leapster does not respond to the stylus pen, it needs to be calibrated.
The following are instructions below on how to recalibrate the leapster.
1. Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
2. Hold down the Home, Hint and B buttons simultaneously.
3. When the screen changes, press the A button.
4. Using the Stylus, touch the center of the targets.
Thanks for using Fixya.
Feb 06, 2011 | LeapFrog Leapster Electronic Book:...
The Leapster turns on and the sign in screen comes up but the touch screen does not work. Recalibrating does not work. Can't get past the sign in screen
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
Jan 21, 2011 | LeapFrog Leapster 2 Learning System
The touch pen doesn't work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Nov 28, 2009 | LeapFrog LeapSter L-Max Console
We have leapster two, we have power but the pen does not work
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Aug 06, 2009 | LeapFrog Leapster Learning Game System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
Leapster pen not working
May 12, 2009 | Leapster Learning System
Leapster can't read input
You need calibration
Touch Screen Calibration is as:
1.) Ensure that a cartridge is NOT inserted.
2.) Hold down the Hint (’?') button while turning the unit on.
3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
4.) Touch each of the crosshairs that appear with the stylus.
5.) Restart the unit.
Dec 25, 2008 | LeapFrog Leapster Electronic Book:...
The pen won't work on my daughter's leapster
Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
Leapster Learning System Logo
2,055 people viewed this question
Top Leapster Toys Experts
James Hensley
James Hensley
Dennis Crouse
Tom Chichester
Are you a Leapster Toy Expert? Answer questions, earn points and help others
