Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Murray rear engine riding mower locks up after riding briefly
She started up and began mowing. After 20 seconds, it screeched to a halt and turned off. I restarted it and mowed another 20 seconds until the same occurred. Now, it will not even start. Just a click when I turn the key. Fuse is good. Any thoughts? (Mover is 8 years old).
  • 1 more comment
  • mktopping May 27, 2009
    Ok, I am an idiot. I now realize that she froze up because my oil was practically drained. So, here is the question: Now that she doesn't turn over when I turn the key, is there anyway to "unfreeze" her (after I fill the oil of course) or have I permanently frozen her. There is no pull start. There's a round screen over the engine. Thoughts?
  • mktopping May 28, 2009
    Panilling9, I followed your steps and BINGO! It started up after a few tries. THANK YOU
  • Dwain Pippen May 11, 2010
    Can you lay your hands flat on the screen on top of the engine and turn it by hand, backward or forwards and will it turn all the way around? Did you check the oil before use?
  • 376 Answers
I really don't think at this point there's much hope for your engine. I would say it was seized from lack of lubrication. The piston is likely 'galled' to the cylinder frrom heat and probably wouldn't last even if you did break it loose and started. Still, you have nothing to lose. Soo.. put the correct amount of oil in it, remove the spark plug and spray a penatrating in the cylinder. Take a 5/8 socket and breaker bar and turn the bolt on the botton of the engine pulley clockwise and see if it breaks loose. Good luck
Posted on May 27, 2009
  • 284 Answers
Check your oil of course
does the engine have a pull rope?
if so try to pull start it
is the motor free?
next step do you have a good battery?
under the motor cover. if you have a pull start is a clutch type mechanism that engages when you pull start it
remove motor cover and on top of the clutch you will see a small hole put oil in that hole and work it so the oil goes to lubricate the shaft that the clutch spins on this mechanism and spins freely only ccw cw it catches and turn the motor,
just a thought it may or may not be related
Posted on May 26, 2009
  • panilling9
    panilling9 May 27, 2009
    i would say longhorn 294 has great input
    you could also remove that screen and locate the flwheel nut and get a socket to fit it and a 1/2 inch drive ratchet or breaker bar wrench with extension and try to turn it cw an ccw to assist in breaking it lose
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
My murray riding lawn mower stops moving in forward and very slow in reverse after about 20 minutes of mowing.
the balts are probably wore out. if they look cracked or thin in spots replace them both at the same time. should be back to new.
Jul 09, 2016 | Murray Garden
I have a Murray 30" riding mower with a Tecumseh TVM195 8hp engine that won't start. The engine seems to be locked. I have removed the spark plug and tried to turn it, but it is still locked tight. The...
Maybe the rope pull start is stuck? Remove shroud and see if you can rotate the flywheel by hand. If it won't move then the crankshaft may be stuck on a broken part, such as the governor gear or camshaft that has broken off.
Aug 04, 2014 | Murray Garden
Engine seized up
Chances are pretty good that you either spun a rod bearing or broke a connecting rod. Either way you are probably looking at a costly repair.
Aug 14, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
14hp twin II Briggs and Stratton 400707 locked up and simply screeches after oil change
remove the tin upper engine cover and look at the gear on the starter yes they do break the gear the gear is only $10
Apr 07, 2012 | Murray Garden
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Jun 22, 2009 | Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Lawn mower
check out murray & tecumesh website
May 01, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
148 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
