Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi SS30 won't stay running
It starts up great, but as soon as the throttle is put into run it dies out, always starts right back up
I had this problem and it drove me crazy with 2 different new and relatively new weedeaters. One the fuel hose was rotten and the filter in the tank was clogged and on both I had to buy the Pacman screwdriver to adjust the carb. Once I got it running I turned the high mixture screw out slowly until it constantly ran great. Havent had a problem since
Posted on Aug 01, 2011
Can be your plue
Posted on May 27, 2009
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Why does my 2004 Ford Taurus start but wont stay running if I let off of the gas or try to put it in gear?
I'd be checking the throttle linkage stop on the throttle body/carb. Sounds like the throttle plates are closing off completely when you let off the pedal. Throtlle adjustment screw may have just backed out also.
Jul 10, 2017 | Cars & Trucks
SS30 Trimmer dies when you squeeze the throttle.
First make sure it is warmed up first. A good way of letting it warm up is to feather the throttle for a while until you can hold the throttle all the way down and let it run full speed for 1 minute. Then try a regular use. If it still acts the same, then I suggest removing the carb and completely clean it out.
Nov 10, 2010 | Ryobi Three Trimmer Combo
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Problem with gas trimmer staying started
Carburetor is out of adjustment. there are two carb adjustment screws on the side of the Carb. they require a special tool that is only $5 from your local mower repair dealer. those screws are the idle and Hi speed mixture adjustments. the carbs on Ryobi are set too lean. turn counterclockise to richen the mixture. just turn one eigth of a turn at a time. start w the hi speed.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
3,147 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
