Question about Palm LifeDrive Mobile Manager Handheld
My Lifedrive wont turn on...
My Lifedrve could not charge,so the battery finished completely.Now it wont turn on,or show any kind of 'life' in it.I tried soft reset but still no difference.Please help!!
  • David Jacobs Mar 02, 2008
    My LifeDrive has the same problem. Been through all the Palm Support resets etc (none actually activated) and got an SRO number for replace / repair for $185. Red light on when in cradle but no activity from any buttons / resets etc. Dead. HAve used two chargers with same resuolt. Chargers work on a TX. So its the LD.
  • 3 Answers
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Posted on May 13, 2008
Get a new charger..or return it..hopfully you got extended warranty. mine did the same and it took like 20 minutes just to have enough energy to restart.
Posted on Nov 28, 2007
My compaq presario r3000 wont charge. its plugged in but when i unplug it it immediatly turns off. the battery life constantly says 0%. it wont drop from that or get any higher. in the bottom right hand...
Sounds like the battery, had similar problems.. if you purchase a new battery make sure you get the right kind there are two types, an 8 cell or 12 cell..
The fix for my pressario involved completely stripping it and soldering 3 pins on the power connector on the mainboard.. not difficult but no mean feat.. now works perfectly (with the inclusion of a 12cell battery)
Dec 28, 2010 | Compaq Presario R3000 Notebook
Problems
Hi, i think the battery has completely run down, i suggest you get another battery and ensure you don't allow the new battery to completely run down before yo charge.
As`soon as it shows low battery, you try charge or shut down to save and give your battery long life span.
I wish best of luck
Jan 06, 2010 | ASUS Eee PC 900 Notebook
Palm lifedrive wont' boot stuck on palm screen
This sounds like the issue where the LifeDrive is stuck in a loop. You can see how to break the device out of the system loop on the Palm Knowledge Base article (26419) located HERE.
Hope that helps get you up and running again!
Sep 12, 2009 | Palm LifeDrive Mobile Manager Handheld
When the lifedrive dies duo harddisk, there are
You have two options one is of course a replacement drive but the other is replacing the little hard drive with a flash disk. The flash drive is nothing more than a 4gb compact flash memory card that happens to use the same connector as the Hitachi hard drive. Of the two I'd go flash myself.
The flash disk is faster and uses far less power so your battery life can increase by quite a bit. I think it is something like 10% of the power. Next to the display this is the single biggest power item. I've heard of the useful battery life increasing anywhere from 3x to about 6x after doing this. You can get the drive or flash from several places online. These are the same CF cards as used in many cameras. Most also offer the installation service.
Here is a link to one place but do a few searches and compare prices etc. Just search for lifedrive, flash, drive or lifedrive hard drive replacement and you should get quite a few.
http://www.usedpdaparts.com/Lifedrive.html
Jul 12, 2009 | Palm LifeDrive Handheld
It ia an acer aspire 3004 laptop. The battery charging % remins at 74% all the time and when I remove the power the lap top turnsoff completely.
Well it surely shows that the battery is not providing backup to the laptop. There could be few reasons for the same defective and faulty battery is one of them.
However i will give you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it is charging the battery and provides you the backup.
The usual battery life is said to be 1 year. if you are using an older battery, kindly get the same checked as well.
Hope his will help. Please let me know what happens.
Regards
Sammy
Jul 10, 2008 | Computers & Internet
Lifedrive won't power on
When you plug the unit into the wall to charge, poke the reset hole in the back of it at the same time. This should reset the internal recharging mechanism in the Palm. Let it sit for a couple of hours and then see if it will come on.
Jan 03, 2008 | Palm LifeDrive Handheld
Life-Drive will not power on.
I don't know how much technical skill you have, but I had the same problem and the warrenty had expired. I thought it might be a battery problem. To make a long story short I unpluged the internal battery and pluged it back in and the system came on.
Dec 26, 2006 | Palm LifeDrive Handheld
Dead Lifedrive
I im not mistaking this unit has a 1 year warrantee. I would contact the #v below to see how to get this back up and alive. Good luck 847-262-PALM
Apr 15, 2006 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive Mobile Manager Handheld Logo
218 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
