Question about Maytag Atlantis MAV6260AWW Top Load Washer
Washer will not agitate but will spin
Our Maytag A510 washer will not agitate.  The belt just slips.  I put on a new belt. but  still slips.  When I tighten belt while it is trying to agitate the moter pulls down and stops like the agitater part is stuck or something.
it will spin out ok but.  does the motor turn on way to spin and the other to agitate?
If you can help us out   Thanks in advance...
Sanford
  • 1 more comment
  • Anonymous Mar 24, 2014
    idler pulley OK, cleaner motor pulley looks OK
    belt slips on motor in spin mode
  • Anonymous Mar 25, 2014
    The tank doesn't spin or agitate. The belt looks like its in good shape.
  • 290 Answers
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Posted on Oct 21, 2007
  • Michael  Lindley
    Michael Lindley Oct 22, 2007
    Just wanted follow up on your washer problem and see what you found out.
    Thanks/Mike
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jan 06, 2015 | Maytag Washing Machines
My maytag bravos will not spin
Oct 10, 2014 | Maytag Washing Machines
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Sep 28, 2014 | Maytag Neptune Washing Machines
Belt slipping during agitation
Bearings are damaged or drum spider damaged .
Oct 04, 2017 | Maytag SAV5910 Top Load Washer
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
Maytag washer agitates bit won't spin
If no one responds to your request try this site and others. This was a quick search on your model… I’m an owner and only have knowledge of the FAV6800AW…… Good luck .... Rich
Oct 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
Squeal that sounds like belt spippage
The motor slides back and forth so there is know way to tighten the belt.The new  belt is needed if your old one shows any ware or if has shiny look to it which would mean its been getting hot and slipping.
May 16, 2008 | Maytag Legacy Series Top Load Washer
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
667 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
