Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
MACHINE DOES NOT SWITCH ON
THE PRINTER DOES NOT SWITCH ON DESPITE THE FACT THAT THERE IS POWER FROM THE POWER POINT AND ITS POWER CORD WORKS WELL ON OTHER ELECTRONIC DEVICES
    President:
  • 2,072 Answers
You most likely have a bad low voltage power supply. They develop problems from heat in the power supply area.
You can google a business called " the parts drop". Give Britt a call and see what he has. He will give you the best price .
Posted on May 27, 2009
Hp p/smart c5280 all lights flashing
Is this your problem:
The power light and about all of the left lights are blinking and there is
nothing on the display screen. Trying to turn off the machine does not work and
results in the same error. "Hard" reboots do not work.
Switch the cords if you have another HP Photosmart printer, even if the
latter one is still working.
I thought of this early but then decided to watse three hours of my life I
will never get back,
Do you have another HP printer with a similar looking power cord?
The cords should go into the back of the printer very easily. I have an HP
C5280 and a newer HP C309 and I just moved. Actually, I have three printers
including an HP 7510. The 7510 and the C309 worked just fine when I set them
up, so I figured they both had to be utilizing the proper cords. But I was
sismaken.
I undid the C309 cord and replugged it and noticed it was hard to put into
that machine, despite that it still printed, just as the one I was using on the
C5280 was difficult to plug in. So I made sure the transformers were basically
the same and switched the cords.
Your first tip that something is awry is if it takes any effort to get the
power cord into the machine in the first place.
Hope this works!
Feb 15, 2011 | HP Photosmart C5280 Printer
My toshiba m645-s4047 does not start despite the fact that the battery is charging
Take out the battery, put the power cord back in, turn on the machine, wait for it to get into windows, put back in the battery.
please rate
Nik
Jan 28, 2011 | Toshiba Satellite M645-S4065 Notebook
I cleared a paper jam in my hp officejet 7310xi/all-in-one and i'm still getting a carriage jam message. How can I get the printer back to normal?
Try to Reset your Printer.Before that search for any paper piece or any other obstacle which preventing carriage movement.
Full reset:
a. Unplug the power cable from printer when the printer is powered on.
b. Press and hold # and 6 while plugging in the power cord.
c. Wait until "Semi full reset" displays ("Semi" appears despite the fact this key sequence is defined as a full reset).
d. Answer questions - Language/country, etc.
Partial reset:
b. Press and hold # and 3 while plugging in the power cord.
c. Wait until "partial reset" displays.
I think it helps.
Jan 10, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Replaced ink cartridge still not working
Please remove all the cartridges, clean the Contact points on the cartridges and on the Printer with alcohol/spirit/acetone using a soft brush, don't touch the print heads, you may damage them.
Turn off the printer, disconnect usb cable, power cord and ethernet cable (if any). Leave it Off for few minutes (fix minutes will be enough), also remove/disconnect the power cord from the mains.
Do some cleaning if you can.
Now press the power button several times. Connect the power cord and power on the Machine without anything installed/connected, again leave it On for few minutes and turn it off.
Connect the usb cable and ethernet cable, Switch on the printer and install the cartridges. If there's no internal problem this will definitely fix your problem.
Good luck.
Thanks for using FixYa.
Jun 30, 2010 | HP Officejet H470 InkJet Printer
Continues to say the "check your color cartridge" despite new cartridge and double checked reinsertion.
Please rest your Machine... to do this follow the instructions below;
First of all, Remove the cartridges, and clean the contact points on the cartridges and on the printer.
  • - Turn off your printer, disconnect usb cable, power chord etc.. open the back door, press the power button several times.....
  • - Now connect the power chord and power the machine while you keep pressing the power button (don't hold down), and let me boot up, leave it On for few minutes.
  • - Turn it Off and install the cartridges, reconnect the usb cable, etc.. and reboot the machine. You'll see how it works. If you have problem even after this, please let me know.
Good luck.
Jun 15, 2010 | HP PSC 950 All-In-One InkJet Printer
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Computer dead despite working power supply (power and charger LED are off)
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Oct 31, 2008 | Toshiba Satellite A215-S7422 Notebook
My SF-5100 has stoped receiving faxes
Make sure you are set for AUTO RECEIVE.
Unplug power cord and re-connect. Do you have a DSL phone line?
Sep 05, 2008 | Samsung SF-5100 Plain Paper Laser Fax
HP PSC 950 auto switch off
The printer is always on despite of the status of the front panel, to turn it off you have to disconnect the power cord.
In some models of HP printers, the printer will power itself ON from "standby" when the PC sends it a printing job and go back to "Standby" when the job has finished printing.
Apr 24, 2008 | HP PSC 950 All-In-One InkJet Printer
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
