SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
SOURCE: I have a culligan 100 series water softener. It
the wasre filter is plugged up if not shutting off
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
SOURCE: water has been trickling to the drain
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
SOURCE: Looking for ''Culligan soft-minder meter'' (part# 01-0073-47)
It could be the meter assembly itself. This is the old style with the clear meter dial on the timer mechanism. There were several issues with this meter assembly. You can take the valve off and take it to your Culligan dealer for a "bench test". Also check the meter cable in back of meter assembly. It may have come apart. These parts are only available from Culligan.
RJ
