Question about Garden
Change coil on B&S 550 mower
My wife brought home a mower (Briggs and Stratton 550) that has a bad coil. How would I replace this?
  • 420 Answers
Remove the cover with the recoil starter, the coil is mounted next to the flywheel by two 5/16" screws.
Before removing the old coil find something around the garage that is the same thickness as the space in between the coil and the flywheel, its easiest to use something non ferrous such as a piece of aluminum beer can doubled over.
Remove the screws and coil, unplug the ground wire from the old coil and connect it to the new one. Bolt the new coil in place, you must space the coil .030 away from the flywheel, use the shim you made earlier, I use a piece of brass shim stock .030 for this but almost anything will work so long as it is the correct thickness. Re-install the cover, connect the plug wire and give it a try.
Posted on May 27, 2009
Why won't engine start after doing all these repairs
Make sure it is the correct spark plug with the correct gap. Then check to ensure that fuel is being delivered and is not bad
Jul 30, 2014 | Briggs & Stratton Briggs Stratton...
How much oil for a Poulan Pro 550 lawnmower?
On the Briggs and Stratton site they call for 20 oz but tell the owner to confirm the capacity with the dip stick reading.
Jun 11, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
How much oil is needed for my Poulan Pro 550 lawnmower?
Briggs and Stratton call for 20 oz but warn to confirm the level with the dipstick reading.
How do you check if a spark plug is good on a lawnmower
take it out and look at it put the wire on the end hold it to metal and crank it over to check for spark no spark doesn't mean the plug isw bad but a bad coil if the plug has build up of carbon replace it
Sep 03, 2012 | Briggs & Stratton Briggs Stratton...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
How do i clean the air filter for my poulan pro 550 series
You can only clean it if it has a replaceable (fabric-type) filter...If it is paper, it is disposable and will have to be replaced if bad.
Jun 10, 2010 | Poulan Pro PR550N21RH 21Inch 190cc Briggs ...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
