Question about Gigabyte GA-P35-DQ6 Motherboard
Can not copy a part of XP OS file
How to update BIOS for GA-P35-DQ6? My English is poor...
  • tsjz0512 May 27, 2009
    I try to do it.
    You are kindly.
  • Gigabyte Master
  • 4,806 Answers
Hi there.
Go here to Gigabyte support and download the BIOS update you need>>>>>
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_List.aspx?Keyword=GA-P35-DQ6
Good luck and thanks for using FixYa!!
Posted on May 26, 2009
Markfun_load_nt_driver
Hello you can find drivers, and the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=2637#dl
Maybe the harddrive is damaged, or you have a virus.
Try to install windows again.
Good luck
Oct 18, 2012 | Gigabyte GA-P35-DQ6 Motherboard
How to enter Safemode in GA-P35-S3G Giagabyte motherboard?
In general, to go to safe mode of your OS you need to keep tapping the function Key (F8) while starting your computer.
If you are referring to safe defaults of your motherboard please refer to the following link to download the manual that has the load safe defaults
http://download.gigabyte.asia/FileList/Manual/motherboard_manual_ga-p35-s3g_e.pdf
Nov 14, 2010 | Gigabyte GA-P31-S3G socket LGA775...
I overclocked my Gigabyte GA-X48T-DQ6 motherboard and now it won't boot
If you mean that nothing appears onscreen when you press the power button but you can hear the fans working then try this.
The quickest way to restore default bios settings is to remove the battery on the motherboard.
Important ..... Disconnect the power leads FIRST
Gain access to the motherboard and search for a small coin shaped battery. Note which way it fits into the holder, then remove it and leave the PC for 5 minutes. If you have a manual you can also check for jumper settings to discharge the bios battery.
Refit the battery (the correct way) and plug in the power lead. Cross your fingers and power up.
Jan 19, 2010 | Gigabyte GA-X48T-DQ6 S775 X48 ATX DDR3...
Gigabyte ga-p35-ds3l (2.0) will not flash bios from usb. don't have floppy. can save current bios to usb, and will read new bios however I get no prompt to replace current bios. what should I do?
first never flash your bois in windows it is not good for the mb, restart floppy is the best way, so get a stiffy drive and do it the pc, hope u downlaoded the never bois, at the post screen check to c if there is a flash option f8 or sumthing then from ther u will be directed
Oct 07, 2009 | Gigabyte GA-P35-DS3L Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
I want Windows Xp with out service pack
M8! you need to look for one of the first versions of XP on ebay or something. You cant find any XP without any servicepack today.
And IF you find any, dont forget to deactivate the updates or you will get the servicepacks installed sooner or later.
Good luck
Nic
Mar 13, 2009 | Gigabyte GA-P35-DQ6 Motherboard
Well my system temperature is reaching heats of 50oc under load and I believe it is making my computer freeze causing me to restart. I was wondering how exactly this temperature is measured and where...
Many motherboards take two temps. Motherboard temp and CPU temp. CPU temp is the most common problem. Check there first. You might need a faster fan or a larger heat sink. Also make sure the pc isn't enclosed in anything. It needs to have air moving around it on both main sides, the front and back.
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
System temperature too hot
Its measured in Celsius. Meaning alot higher in Fahrenheit. That would be the Processor.
You are looking for something that will be Square or on a Card that is in the motherboard.
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Bios
I apologize for not seeing you need a bios upgrade. Can you locate the manufacturers name on the board for me?
With that I can find the appropriate bios update ( bios updates are specific to manufacturer not chipsets ).
Feb 24, 2008 | Intel Desktop Board D845WN Motherboard
Gigabyte GA-P35-DQ6 Motherboard Logo
94 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
