Question about Intel Motherboard
Not booting, i mean even getting past post.
Upon pressing power button, led constantly beeps. never  gets to cdrom, hd, or floppy. monitor doesn't respond.  has just been reassembled, re-installed 2 memory sticks ( 256Mb each), cleaned entire system. fan on pwr supply works. fan on motherboard has not kicked in.  everything is onboard. this system has no nics. the only card in a slot is a modem.    help?    i think the problem lies in the motherboard, bios or the pwr supply.
 helllllllllllllllllllllllllllllllllllpppppppppppppppppppppppp???!!!!!
  • 5 more comments
  • loseend Dec 09, 2007
    when i turn on the e-machines the power comes on but the mointor just blink and nothig happen. And i can not get the bios are any thing to work
  • Anonymous Feb 25, 2008
    i have a p23g v.3.0 mobo i wonder what happen, it cant even detect the monitor...but the system unit have lights on in it...the keyboard wont get anything though
    please help.........! i"ve already dislodge the pc battery to reset the bios
  • Anonymous Apr 15, 2008
    hi i got an IBM P6 USA 2001 MOTHERBOARD ive i tryed everithing but still nothin ive put 2 sram 256 and nothing the monitor dosent light
    wene i swithc the pwr it makes 3 bips plus 1 long bip
  • franc_el Jun 25, 2008
    I have the same problem. I did turn power on the computer, nothing happens, purple lights come on and off, some lights on CD,...and then NOTHING.
    Monitor completely off, nothing i can do form the keyboard.
    Keyboard lights do not turn on (motherboard did not recognizes the keyboard?),...mouse led (laser?) is always on, even if computer is off, except power supplyis turned off, of course. Does mother board fails?,..i set the "hat on BIOS" on the chip,...and nothing
  • JAYBEE1 Jul 31, 2008
    I Have lost BIOS phoenix technologies on the first page after start up.
    If I change my BIOS settings for "Load Optimised Defaults" would this clear
    the problem. Occasionally have trouble starting up and first page comes and goes in a circle. Please advise soonest
  • scottw24 Aug 12, 2008
    Replaced power supply to no avail fan does not run and no light on mother board.
  • Anonymous Feb 14, 2009
    the pc does not beep,cdram,flappydo not lightup. Does not get the post and monitor is blank. These are the specifics{p4 with 256mem on board}
I found a great solution - I bought a new computer from pc world an advent with 3gbyte memory and
insurance to keep it running okay. I had tried two repair men who handed it back as repaired but the
same fault came back within 2 days. I gave up - so thanks for all your replies.
sincerely Jaybee1
Posted on Sep 18, 2008
I get a constant beep 1-1-1-1-1-1.... etc i started counting, but lost count at 15
I'm convinced it's memory, but i've tried other modules
Posted on Mar 17, 2008
So whats the fix here anyone know.I moved memory to other slot and that didnt do anything
Posted on Feb 11, 2008
    Problem Solver:
  • 12 Answers
How many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Posted on Feb 05, 2008
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
Apr 21, 2012 | Compaq Computers & Internet
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Asus motherboard p5b-mx wifi won't display vga
this can be caused by a number of issues the leading being RAM (no post beeps at all). before you do anything else pull all existing RAM and install a KNOWN GOOD STICK in their place and try again.if that doesn't work try resetting the mb (see the owner manual on how to do that) bios settings to defaults (this generally selects onboard video). if you have an installed video card within the system also remove that (even though you aren't using it). is that memory compatible you have there with the board? if its too slow the stick may be fine but mb may not "think" so. do you have keyboard "flash"? is the hard drive indicator constantly lit? how about cdrom drives and/or floppies? can you eject same? all this points to incompatible or "bad" memory as the main culprit.
Dec 12, 2008 | Computers & Internet
ECS P4M800-M V 2.0 wont POST
may u have a grouded DVD drive, did u try another DVD or CD drive? may be it will help.....
Aug 14, 2008 | EliteGroup ECS P4M800-M Socket...
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
Mar 19, 2008 | Toshiba Tecra 8100 Notebook
Hd install
Enter BIOS, at start up press Delete key every couple of seconds. PC vary, some require pressing the F1 key or F2 and others reqire F10. Once in the BIOS you'll need change your boot order. Again PC's BIOS's vary. Usually Floppy is first, CDROM second and Hd 3'rd. Save Bios and restart. If you boot media is a floppy disk your PC will go there 1'st, than to the CDROM. If boot media still is not seen. Check connectors to the floppy and or CD make sure cables and power connectors are tight.
Dec 16, 2007 | Computers & Internet
Intel Motherboard Logo
318 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
