Question about Fuji FinePix A310 Digital Camera
  • 1 more comment
  • Anonymous Nov 08, 2007
    Started getting the "Focus Error" for no apparent reason. Tried turning on/off, removing/reinserting batteries. Still not working. Fuji says take it/send it to repair facility.
  • danielle4315 Nov 20, 2007
    You see my problem is the focus error thing keeps showing up. At first when it did that I hit it with my palm and it would be fine, now it just says focus error. I have tried hitting it, tried zooming in and out and tried taking the batteries out nothing works.
  • 4jam Mar 11, 2008
    focus error is on and you cannot use the camera. I have taken the batteries out, I tried going thru the menu, I have taken the memory card out, I bought new batteries and still nothing. This camera was not cheap.
I had same thing. I took camera to bits and still didn't work. Then one day just before throwing it in the bin with batteries in and lens extended, I grabbed the outer ring (bigger part of lens near the body) and pulled it out a little further. I think there was a slight click then the red light turned green and everything was back to normal. Maybe I was lucky,but its worth a try because it definitely worked for me. Cheers John
Posted on Jan 22, 2008
I was the second post. Since then I tried taking the batteries out over night. That didn't work. But then today I tried running the zoom in and out and noticed that it was not reacting properly. It was either delayed or wouldn't zoom at all. I kept running it in and out and I whacked it in the palm of my hand. Suddenly the "Focus Error" message disappeared, it focused and I was able to take a picture. I think this relates to Solution #1 above. This makes me wonder if a lubricant like WD-40 would help. I don't expect this solution to be permanent, but for the moment the camera is working.
Posted on Nov 14, 2007
  • 3 Answers
Taking to fuji repair: € 125,- its a solution but better by a new camera.
Problem: focus lens is stuck on inner or outer position.
Solution: open lens, remove bateries.
remove with sharp knive outer chrome lens cap, put a smal screwdriver between outer lens housing en lens(3 sides)> becarefull!
If you are lucky the lense is comming lose, put batery back and open close lense, my be you are a lucky as me, camera run until a year again. Regards
Posted on Nov 13, 2007
How to fix fujiflim xp50 zoom error
You've given us a lot of information, but unfortunately no specific description of the error.
Jul 08, 2016 | FUJIFILM Fujifilm 16233283 Compact Camera...
Sony video camera hdr-cx110 ... blinking error code E:61:00:00 auto focus doesn't work... I can see inside the lens and see movement when I use the zoom in and out ...
Hi Hedonismious,
If the camera is under warranty the best option would be to get it repaired for free via the service center.
Either they will repair it or replace it.
From the error code , it seems to be the zoom lens malfunctioning which you cannot repair by yourself and the error in itself means that you need to get in touch with the service center.
It's a chip level fault or a firmware fault which SONY authorized center can deal with.
What you need to do , i contact the service center and just inform them about the error code that you are receiving , and they will come to know as to what is the problem and direct you to appropriate department and method to get this problem resolved
I would also like to caution you , that you should not attempt anything on your own in this situation because it may result in further damage to your camcorder.
Hope this helps ...:) Let me know in case you have any queries.
Sep 08, 2011 | Sony HDRCX110 Camcorder
Fujifilm finepix a820 zoom error ... i turn the camera on and it wont focus... message on lcd screen is zoom error. it will not take picture and when i turn it off agan the zoom bit wont go back inside
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Oct 28, 2009 | Fuji FinePix A820 Digital Camera
F01 error on playback or recording - Panasonic NV-DX100
Panasonic JVC Description
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
E06 Tape drive motor is not rotating or stalled
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila
Jul 11, 2009 | Panasonic Video Cameras
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji FinePix A310 Digital Camera Logo
323 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
