Question about Ricoh Aficio SP C410DN Laser Printer
Ricoh C410DN set the toner cartridge correctly
Replaced yellow cartridge and error message at startup of "set the toner cartridge corretly - yellow". Tried resetting and unplugging with no change. Any suggestions
  • pentiumbug Sep 18, 2009
    I have the same problem too. I refilled the cartridge, and the top is not too fasten now. I locked it in position using some tape.
    The chip are all in place , but the cyan one has a problem, since it generates the error "set the toner cartridge corretly - cyan".
    No way I can get out of this.
    HELP!
  • angelus316
    angelus316 May 11, 2010
    Is it a genuine cartridge or compatible one?
  • 95 Answers
If you look at one of the other colors you can see how the toner cart door slides under some plastic to open it. I bet the yellow one is broke. Tape a folded piece of paper to the end of the cartridge. That might hold it down so it will work.
Posted on May 29, 2009
When placing the cartridge (facing the front of the printer) put in the left side first as you lower the right side and tighten it PUSH IT TO THE RIGHT. I suppose that unless you push it to the right the contacts are going to be misaligned.
Posted on Sep 22, 2009
How can i fix the 'replace toner cartradge 'which is show in ricoh printer 4210
Please follow the steps to replace the toner cartridge on the attached link: http://support.ricoh.com/bb_v1oi/pub_e/oi_view/0001037/0001037078/view/hardware/unv/0084.htm
http://www-it.desy.de/systems/services/printing/help/Manuals/Ricoh/SP-4210/Manual/hardware/unv/0098.htm?lang=en;view=print
If the message Replace Print Cartridge remains, it means that it is not the correct toner cartridge, replace it with the correct one. If Reset Print Cartridge message appears after correct replacement, it means that the toner cartridge is not set correctly or not installed. Set the toner cartridge correctly. If the cartridge is installed, close the front cover and turn the power switch to off and to on. If the message appears again, contact your sales or service representative.
Apr 17, 2017 | Ricoh Office Equipment & Supplies
Why is it indicating black toner is empty?
[Cause]
This may be caused by the Toner ID switch, that contacts the ID PWB on the Toner Bottle. The Toner ID switch has 4 wire contacts, if one of the contacts become crossed over this error may occur.
[Action]
Uncross and straighten the contacts.
If issue remains replace ID Chip Connector Harness [Part Number: G102 1120].
May 02, 2015 | Ricoh Aficio SP C410DN Laser Printer
Error code SC363
yellow toner is not loading
replace new yellow toner if it did't work replace the yellow toner pump
Apr 27, 2014 | Ricoh Aficio SP C410DN Laser Printer
I have a ricoh c410dn and it has an sc364 error.
sc364 is a black toner density error. Typically, replacing the black PCU will get rid of the error message.
Feb 18, 2011 | Ricoh Aficio SP C410DN Laser Printer
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio  SP C410DN Laser Printer Logo
1,880 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
