Question about Carrier Heating & Cooling
A/C Clogged drain pipe
I think I have a clogged drain pipe in my a/c. Yesterday we noticed water leaking into the house below the a/c unit and when i removed the filter I did not see any ice or anything. I used a shop vac to **** on the drain pipe outside the house and it did remove lots of dirty water and an orange sludge and this seemed to improve water flow out of the pipe. This morning I tried it again and more dirty water and sludge but improved draining as the a/c ran. I shot the garden hose up the pipe and just kept removing water. Now the drain pipe has not drained any water the last couple times the a/c ran and there is a gurgling noise coming from the drain pipe. I am afraid there is still a decent clog in the pipe somewhere. I know nothing about a/c's and have read a lot about blowing the pipe out but I cannot figure out where to disconnect the drain line in order to temporarily pipe it into a bucket in order to blow it from the other side with a hose. Trying not to call a professional, can anyone help?
  • RICHARD GING
    RICHARD GING Feb 15, 2014
    YOU PROBABLY HAVE A CALCIUM DEPOSIT BUILD UP, USUALLY NEAREST THE ELBOWS, BEST WAY TO SOLVE WITHOUT CUTTING PIPES IS TO USE A FIBERGLASS FISHTAPE ROD AND SHOVE IT THRU IF POSSIBLE, SOMETIMES A LITTLE CLR WORKS GOOD ALSO
  • Anonymous Mar 20, 2014
    How to remove inner cover to drain water pipe that's leaking onto the floor
Can you get to the hose in the house unit? If so canned air
Posted on May 26, 2009
Condenser leaking
No reason to disconnect. Just use a snake to unclog the pipe.
Sep 07, 2014 | Heating & Cooling
My basement drains do not have water in them causing a very bad sewer smell. I have 2 drains near each other. Both have no water today but yesterday there was water in them. Could it be a clogged drain. We...
Hi, drains usually have curves in them to allow water to sit in them, this bit of water creates a barrier against sewage fumes (both disgusting and dangerous). This water can evaporate or leak out if the drain has a fault. Try pouring a jug of water into the drains to top up this water barrier to keep the fumes out, could take a few times a month.
Cheers!
Mar 14, 2013 | Plumbing
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Our logixx 8 washing machine leaks water from the bottom when the programme is at drain/spin, water is being pumped to the outlet pipe but also flooding the floor from the bottom of the casing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
Sep 20, 2011 | Bosch Washing Machines
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
WATER LEAKING
Water should come out of the back of a wind unit when it is humid out, usually a drain hole. If water is leaking inside from a window unit, check that the outside drail hole is not clogged or maybe it is not tilted downward enough outside (Usually a very slight tilt down toward the outside to help the water drasin out the back outside). Also, if you have excess water forming, you may need to clean the coil. For central air units water should be drippng outside the home via a pipe or tubing and if the drain tube or pipe is clogged with scum that forms inside the pipe water will back up and overflow in the house near the heater/air conditioning unit. Also, some units have a pump to pump the water out and it may not be working.
Aug 07, 2010 | Heating & Cooling
Water clogged in the outlet pipe
Hello
This is the condensate drain line which drains humid water the a/c coil collects.
To clean you can try compressed air,blow through the pipe.Or take pipe apart and flush it out.
Have the unit off when doing this,also clean the collection pan out of debri.
May 12, 2010 | LG Art Cool LA121HNP Split System Air...
Water leaks in the house from under the unit.There is a drain pipe that leads to the outside but we dont know if that pipe gets clogged or needs service.
Open up the inside unit pannel where the drain pipe is and you'll see a drain pan where the condensation water runs out to the drain , clean the drain pan and the hole and then with air pressure from an air compressor blow the drain from inside to outside and go outside the house where the drain discharged and you'll see the clogh that came out from the drain . To keep the drain clean , pour a cup of bleach or clorox every 3 or 4 months through the drain and in the drain pan.
Oct 16, 2009 | Goodman Heating & Cooling
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
Heating & Cooling Logo
432 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
