Question about Microsoft Windows Vista Home Premium Edition for PC
Excessive boot up time
When switching on vista the microsoft bar stays on for 4 min before the vista symbol appears only started today
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    Do you have automatic updates on. There was a pretty big release. Also when did you upgrade to Vista
  • 323 Answers
Click on Windows Defender.
Click on tools.
Click on software explorer.
Click on Start Up Programs
You can scan down through the list of programs that start up when you boot your computer. Many of the programs you install or download and allow to install place a start up line in your start up programswithout your knowledge.
Over time, you are starting up lots of programs you can access after the machine is started. When you find one you don't want to start up, you can click it and at the right hand bottom of the screen you can remove it from the start up list, or delete it completely if it is something you do not want on your computer.
Refresh, reboot, and see if you notice a difference.
Posted on May 26, 2009
Home computer turns on . fan starts up however does not boot; boots after 3 or 4 times switch power off/on
When you do get it to boot up run chkdisk to see if it will find and fix any disk errors.
Feb 28, 2015 | Microsoft Windows Vista Home Premium...
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
C:PROGA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL appears whenever I switch on my PC, how can i rectify this problem?
download (hijack this)/start boot in the safe mode/runhijackthis select to scan/tick every mention ofweb search/selectfix checked/re-boot .this should solve your problem.
Aug 22, 2010 | Microsoft Windows Vista Ultimate for PC
My laptop is using windows vista and when i power it on there is normally a Microsoft logo and a scrolling green bar below appears but now only the green bar appears and i can not log on
First try to boot into safe mode ( tap F8 when you switch it on)
If it boots,run your antivirus/antimalware programs.
It may be worth while trying to restore your system to an earlier date
Jul 09, 2010 | Computers & Internet
Vista Appearance changed to 98 style in the windows and start bar only. Custom background is still present but it's all light grey as in windows 98. This has happened after the first time of turning the...
Ok, this should fix your problem.
1.Right click on an empty spot on your desktop
2.Left click on "Personalize" from the menu
3.Select "Themes" from the personalization window
4.Choose "Windows Vista" or "My Current Theme" from the dropdown and click "OK".
Your screen will go Black and White, then return to normal. Look forward to hearing back from you soon.
Feb 24, 2010 | Microsoft Windows Vista Home Basic for PC
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Microsoft Windows Vista Home Premium Edition for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
