Question about Ricoh Aficio CL7200 Laser Printer
My Ricoh Afficio 2232C doesn't print and it gives me this message: "Functional problems within your computer. Turn operation on then off. If the error appears again, call service. SC 440-01."Several times I turned it off, waited 10 mins. and turned it back on but the message remains. I did a google search and found out SC 440-01 is a "paper jam". How then do I fix the problem? Thank you for any help you can give me. Bonnie
  • 95 Answers
A 440-1 is a black drum motor lock. The waste toner in the black pcu is backed up, more then likley. It is not easy to fix. You could replace the black pcu but it will happen again. The usual problem is oil in the main waste toner system. It clumps up the toner and clogs the part where all the waste toner comes together for entry into the waste toner bottle.
Posted on May 26, 2009
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
Functional problem
change the td sensor below the developer unit or if possibly change the complete developer unit
Jan 02, 2014 | Ricoh Aficio 1035 Copier
Functional problem sc302 in ricoh afficio 1315
this is a charge issue - a simple fix would be to remove the pcu and clean round its outside and then clean the contacts to it inside the machine - if this doesnt work the pcu needs stripping down
Oct 22, 2013 | Ricoh Aficio MP 1600 Black and White...
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Apr 16, 2013 | Ricoh Aficio 2232C Color Copier
Error code sc 680
Refer to BCU/MUSIC communication error.After the engine CPU sends a message,the MUSIC CPU does not respond within five seconds three consecutive times.
Possible cause:toner cartridge memory chip loose connection,memory chip problem,memory chip cable wiring problem.
Turn the main switch OFF/ON.Check if the toner cartridge is installed correctly,replace the toner cartridge,check the harnessess are not damage or replace BCU board.
Feb 14, 2013 | Ricoh Aficio 2232C Color Copier
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
May 08, 2010 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio CL7200 Laser Printer Logo
981 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
