SOURCE: replace starter motor in a cub cadet
What model do you have.
If its a twin cylinder kohler,you will have to lift the motor
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
SOURCE: Cub cadet 2160 when turning ignition switch in
You have either a short in the solenoid trigger circuit, and a faulty solenoid. To check, disconnect the small trigger wire on the solenoid. Turn key to 'START'. If fuse blows, there is a fault in the wiring. If not, the solenoid is faulty.
SOURCE: Fuse blows when you turn the key .Cub cadet zero
One thing I would try is to remove positive cable from the solenoid and the positive cable from solenoid to starter.Then I would temporarly hook positive cable from battery and see what it does. If it goes right ahead and blows th e fuse then you probably going to need to replace the starter.Thank you
