Question about Garden
Briggs engine identity problem on craftsman tiller
I have an old craftsman 5HP tiller that needs a carb overhaul. The model stamped on the cooling cowl is 143-707012 ser# 92970. I can't even locate this engine on the briggs site! please help! thx
  • 284 Answers
Sears.com
enter your mod#143.707012
Posted on May 26, 2009
I have a PowerPro 5 hp rear tine tiller with a 5hp B&S engine mdl 352-02. Where can I get some schematics of the engine?
First you need the model and type from Briggs then you can look at several online source for engine's ipl,
Here is some guides on finding your engine's numbers.
Briggs Stratton Model Number Locator
hey also have the ipl and parts for you to order from or you can support your local dealer.
May 10, 2015 | Garden
Why won't my rotor tiller stay running after starting Its a briggs and stratton
95% of run ability problems are carb related. It needs to be disassembled and cleaned. Do you leave gas in it at the end of season,if yes always drain the tank and let it run till it stops next time before storage. Good luck
Jul 08, 2014 | Husqvarna McCulloch Garden Tiller, 5hp...
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
How do I know what carb kit to get for a 5hp Briggs and Stratton motor on a Masport Rotary Hoe?
Take the model, type, and code number from the motor with you to the local shop and they should be able to identify the proper kit.
The numbers are usually stamped on the flywheel cover. either on top ( by the head) or on the side or on the front directly over the flywheel fan.
Oct 30, 2012 | Garden
Wizard rototiller model 5hp. Briggs. Not getting fuel somehow. Fixed carberator. Spark plugs cleaned everything out... what could be the issue
is it a bowl style carb and you cleaned it is it a diaphram style and you replaced the diaphram ?the older 5hp briggs engines would run fine if you started it with carb cleaner some leaked head gaskets and could create enough vac to draw in the fuel
Mar 28, 2012 | Briggs & Stratton Garden
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 | Garden
Same problem - Slow engine speed doesn't run smooth either
You should look at the numbers AFTER the model and type number you noted in your post. The first two digits of the CODE are the year the engine was made. This looks to me like an old 5hp Briggs....old enough that it wouldn't have electronic ignition. If it has the old points and condenser, it could likely need a tune up. Electronic ignition modules or electronic ignition coils are available for this engine - see your Briggs dealer.
If you had the gas tank off, did you replace the gasket between the carb and engine block? This particular engine uses 2 (two) gaskets, not one.
By the way, you don't want to make a governor spring. It's best to use the one specifically manufactured for this particular engine or you run the risk of over-revving.
Jun 07, 2009 | Troy-Bilt Pony Garden Tiller
Can't find filler plug on transmission
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Apr 24, 2009 | Craftsman Rear Mount Tiller
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
Garden Logo
252 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
