Question about Samsung Propel A767 Cell Phone
Samsung Propel 767 only displays "Download" on its screen.
The phone was dropped in water, dried out, and when powered on only displays "Download"
  • jmusgrave567 May 26, 2009
    How do I remove the internal memory? Also, another thread on this site said to let the internal power run out (How long does that take?) and then power the phone back on. Does that reset the memory?
  • 432 Answers
There should be some way to reset the phone / handset - you could try and leave the battery and memory out for a while and put the phone and memory in a warm dry place for a good 24 hours and try it again.
If it still does not work then if its under insurance / warranty then get it replaced. If not then there may be a key combination you can do to reset it ie the power button and one of the other buttons on the phone holding them down together for several seconds for example.
http://www.mobiledeployments.com/how-to-reset-att-samsung-propel-a767/
Soft reset:
Smartphone devices don’t have reset button so simply:
1. Press the Power Button and turn the device off
2.
Press the Power Button and turn the device on
Any stuck program will be cleared from the memory
Alternatively remove the battery
Hard reset:
You can easily reset your phone to its default settings. To reset your phone:
1. In Idle mode, press the Menu soft key, then select Settings ➔ Reset Settings.
2. Select ALL
3. Press the middle button to make a selection press the OK soft key
4. Enter your “user defined”password and press the OK soft key. (There is no default one, so unless you created one you don’t need it.)
At the “Reset Settings?” prompt, press the Yes soft key to reset, or the No soft key to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Alternatively:
You can reset only your problematic area:
• Sound Profiles Settings
• Display Settings
• Phone Settings
• Alarms
• Bluetooth
https://www.wireless.att.com/support_static_files/manuals/Samsung_Propel_A767.pdf
Posted on May 26, 2009
  • Shane Russell
    Shane Russell May 27, 2009
    For internal memory there should be a slot on the side of the phone somewhere ( may be covered up by a rubber pad of some description ) which you can pull back and remove the memory card.
    Brigadier General:
  • 3,917 Answers
Irrespective of any model of mobile phones when they come in contact with water high chances are there to have the circuit damaged. Its nice that you dried it out but still need to follow a proper method of drying the things. Please follow the bellow link which shows a video how to do it:
http://www.youtube.com/watch?v=8AnZQc3RCao
In your case since it shows "Download " on turning on the display clearly shows a memorey problem which has developed. Either remove the memorey and then try rebooting or need to replace the memory.
Thank You
Phone displays "DOWNLOAD" in a red bar across a black screen.
The phone has been exposed to moisture, so you must let the phone dry out. Take the battery out immediately, open your ports to expose as much of the inside and let it dry out a day or two. Should come back. Good Luck.
Apr 17, 2010 | Samsung Propel A767 Cell Phone
I dropped the phone in water and now that it has dried out it only says download.
i know that happened to me yesterday night im trying my best to blow dry it and i found out u hav to replace your battery
Feb 11, 2010 | Samsung Propel A767 Cell Phone
Wet Phone with Download screen
it may sound funny but put the phone, battery and nething else that got in a bag of dry rice. it will soak up any water left in the phone. that may fix your problem.
Sep 13, 2009 | Samsung Propel A767 Cell Phone
Propel Dropped in water. Now the screen's blue and green
I put mine in a seal bag of uncooked rice for a day (to absorb the moisture) and then tried this solution and it worked!! Good luck
noavatar_s.gif N1XGamerGod
Rank: Guide
Rating: 78%, 14 votes
Okay heres what you do guys!!! Just happened to me today and I fixed it. Mine was at the bottom of a hottub for 2 days XD.
The power in the phone needs to run out
then, plug the phone up
wait about 30 seconds(download screen should be up and it is charging xD.)
Then Take the battery out and unplug the charge from the phone
Stick the battery back in
Wait about 30 more seconds
Hold down the Red Phone untill it turns on.
FIXED! YAYYYYY!
Aug 14, 2009 | Samsung Propel A767 Cell Phone
My fiance dropped my propel in the toilet for about a minute. It was on and dripping water. I made him turn it off and take the battery and sim out of it. He dried it, and put it back together. It's been...
exposing the phone into water will cause problem to your phone. a corrosion inside of your phone might occurs that's why the screen messed up. I strongly suggest that you call Samsung hotline 1-800-726-7864 to fix your problem. Their representative will create a service ticket for you to be able to send it in for repair.
Jun 28, 2009 | Samsung Propel Cell Phone
Samsung Propel - Download Message
ok had the same a767 propel for att in white
Drove me crazy that the phone was in download screen mode
So best fix and it is proven :is to open phone and disconnect small battery on mother board of the phone then leave it out for about 2 mins and leave it out
then put it back together all fixed works and powers up just fine :)
Jun 17, 2009 | Samsung Propel A767 Cell Phone
When the phone powers on the screen displays "Download"
FIXED! YAYYYYY!
May 19, 2009 | Samsung Propel A767 Cell Phone
Wife dropped her Propel into glass of tea. got it out and dried it off, now displays "Download". What does this mean?
By "dried it off" I assume you just dried the outside, this will not prevent internal damage obviously, the best thing to do is immediately remove the battery to prevent shorts in the I.Cs and then remove the housing and place in the hot water cupboard for a few days. Your wife's phone has probably suffered a short and is probably therefore wrecked.
Apr 30, 2009 | Samsung Propel A767 Cell Phone
Samsung Propel A767 Cell Phone Logo
71 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
