Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
Lost setup and reset
My d-link g710 lost driver and setup i try reset many time but no config setting
5 Suggested Answers
SOURCE:
Benimur
  • 6966 Answers
SOURCE: Wireless repeater
Might it be that your problem exist because both the 2Wire HW1700 wireless modem and the D-Link DWL-G710 have their DHCP features enabled? During the setup, use static IP adds, disable the DHCP function of the HW1700, follow setup instruction/procedures of the DWL-G710.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 19, 2008
SOURCE: Setup range extender
i found the solution. first reset de DWL-G710, change the ip 192.168.0.30 to 192.168.1.253 (obiously change your IP of LAN card for 192.168.1.252 example) in the G710 go to network and in the gateway put 192.168.1.254. go to wireless Site Survey, select your 2wire net, connect, select the channel of your 2wire, select your security, write your key and apply and ready to connect :D. Later but secure :)
Saludos from mexico
Posted on Jan 17, 2009
WiFiNut
  • 53 Answers
SOURCE: D-Link DWL-G710. I can't login because I've forgot my username
When pressing the reset button, you must hold it for about 10 seconds.
Posted on Jul 03, 2009
  • 34 Answers
SOURCE: DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Posted on Oct 18, 2009
Linksys lost my key code
before thinking of reseting router try to conencto computer with the ethernet cord to acces linksys config site at 192.168.1.1
admin user : blank
admin pws : admin
goto wireless setup
ssid
wireless security
thats the pws
Jan 19, 2010 | D-Link NETWORK CARD DFE550TXREF Network...
Linksys Routers lose setup
I Had to replace a Linksys for a client because every time was a power outages the router was losing the setup. So try unpluging the power supply.
Jan 06, 2010 | Linksys Wireless-G Broadband Router
I have an Airplus Wireless Range Expander how do I find the IP?
just press and hold the reset button till the lights on the front blink to go back to the factory defults.
factory IP address is 192.168.0.30
type that in your browser address bar after you reset the G710
Nov 05, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Got a DWL-G710 wireless extender that will not
First I would try a reset, as this extender should would with your default settings of your network.
I would suggest just giving your router a reset. Here are the procedures for your particular router:
Reset Procedure
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
make sure to setup your wireless security again and make sure to set an admin password on your router after the restart.
Oct 31, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 keeps disconnection from router
sounds like it isn't working anymore.
try resetting it and configuring it again with the network cable
Dec 26, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
D-link range extender
with d-link range extender Im trying to cofiger it with conect it direct to the computure but the result not find server
Mar 16, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710
Move the repeater directly next to the router, connect to the repeater with a laptop/desktop and enter the configuration utility, see if you are even able to establish a "signal" status. If not, you may have a defective product or extreme amounts of emi.
May 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
42 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
