Question about Apple MacBook Pro Notebook
I want to connect my Macbook Pro (Mac OS 10.5) with my Onkyo Receiver via Toslink optical cable. How could I do?
How to connect Macbook Pro to Onkyo Receiver via Toslink cable
  • Apple Master
  • 739 Answers
As Verb75 says - you just need the right cable.
Posted on Jul 26, 2009
    Problem Solver:
  • 19 Answers
There is an optical cable that you can buy. It needs to have a MINIPLUG on the one end and a standard Toslink on the other. This will give you the digital audio out of the MacBook Pro.
A company called Proel make the cable you need in varying lenghts.
www.proelgroup.com
Hope this helps
Verb
Posted on May 30, 2009
How do connect surround sound receiver to my tv
use the optical port (toslink cable needed)little square with flap will be lit red or use rca cables red and white audio out fron tv to any port on reciver(aux,cd,dvd,ect) the reciver will have to be turned to this for the surrond to be heard
Sep 06, 2014 | Onkyo TX-DS575 Receiver
Can i use a toslink cable
No. The Toslink cable would only carry the audio portion and not the video. That's why the HDMI cable and it's related firmware were created. HDMI can pass both video and digital audio. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 29, 2013 | Pioneer HTZ-55DV System
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
I have a mac air and I am having volume problem. When I attempt to adjust the volume I get a circle with a line over it. Also I can no longer watch video since this problem occur. The video would load play...
The problem is that the headphone jack for you Macbook Air is a copy Analog (standard headphones) and Optical (toslink) jack. The jack has a small microswitch that detects when the cable inserted into the jack is a metal analog connector or a fiber optic toslink cable. The reason your seeing the "NOT ALLOWED" sign (circle with a slash through it) is because you cannot not adjust the volume on the sound when the output is in DIGITAL MODE. To verify this, drop down the jack cover on the side of your macbook air and place your index directly in-front of the headphone jack about 1/2" away from it. Is you finger glowing red? That's because the fiber optic LED is turned on and Mac OS X thinks that there is a toslink cable inserted into the jack.
This is a known hardware problem with that type of combo-jack and affects a lot of other Macbooks, as well.
If your Macbook Air is still covered by Apple Care, take it into an Apple store and have them replace the jack. I know this is a pain, but it is the correct answer.
If your Macbook Air is NO LONGER UNDER WARRANTY, you can attempt to fix this yourself, but be warned, you could break stuff!
Here is a thread at the Apple support forums discussing this issue: http://discussions.apple.com/thread.jspa?messageID=3255575
The above link is good background reading and will help you understand the issue further. The short answer is that many people have inserted a toothpick (other similarly sized NON METAL object) into the headphone jack, wiggled around until the microswitch is clicked off, then normal audio resumes. My 2009 Macbook Pro 17" has the same issue, but I have found that I can take a regular pair of headphones, insert the jack, wiggle it, remove it, reinsert, remove it....and repeat this process until the switch gets toggled. It's annoying, but I have to do this until I get home and can send it back to Apple for warranty work.
May 21, 2010 | Apple MacBook Air
Can't connect Digital Optical Audio cable to receiver
The TOSLINK optical connector is almost aquare and should be the same on both blue-ray and on the receiver. There are 4 orientation you can try and only one fits. Blue-ray can have the connector installed rotated, but it should be the same connector.
http://gallery.techarena.in/data/513/thumbs/Toslink-and-Coaxial-Connectors.jpg
Looking at the cable at Amazon I can see that it is the correct cable. If it really doesn't fit, maybe you have damaged cable or damaged connector. Try the other end of the cable and/or other optical input on the receiver.
BTW there is also combined analog/optical jack connector. It looks like normal jack socket, but accepts also optical signal. But this is not called Toslink and usually is not used in home theatre devices.
May 12, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Digital Audio out in MACBOOK PRO.
Connect external speakers, headphones, or optical digital audio equipment. The headphone / line output jack accommodates optical digital audio output, analog audio output with a 24-bit, 44.1-192 kHz D/A converter, digital audio output up to 24-bit stereo and 44.1-192 kHz sampling rate and supporting encoded digital audio output (AC3 and DTS). For analog headphone / line output a standard audio cable with 3.5mm metal plug should be used. For digital audio, a standard Toslink cable with a Toslink mini-plug adapter can be used.
You can find the Digital to Analog converted:
http://tinyurl.com/9ms8mv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | Apple MacBook Pro Notebook
Yamaha reciever doesnt recognise hdmi from Mac laptop
Max does recognize receiver over HDMI-CEC.
The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
May 22, 2009 | Yamaha RX-V563 Receiver
Dolby output is Pro Logic II, even though source is Dolby Digital
I know nothing about tivo but dvd player might need to be on bitstream to pick it up.I have to change mine when listening to music. hope this might help.
Mar 26, 2009 | Onkyo TX-SR304 Receiver
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
BA7500g speakers won't work with my mac
I have the same problem except i'm using a macbook and i'm trying to connect the speakers. My macbok accommodates optical digital audio output, but you have to buy a  a standard toslink cable with a toslink mini-plug adapter.  Since the speaker input is a digital coaxial (not fiber, optical) you have to buy a Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter.  good luck. hope this helps
Jan 02, 2009 | Boston Acoustics BA7500 Computer Speakers
Apple MacBook Pro Notebook Logo
415 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
