Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby Motor Sprocket gear.
I just got my kirby from a friend. when i took the front off i found the motor sprocket gear on the floor. I am not sure where it should be put back on at? Please help.
  • Kirby Expert
  • 324 Answers
Hmmmm... not sure what it was doing in the fan chamber but anyways - go HERE and you will see how it is installed (picture next to step #10).
Makes sure you use 2 gears of the same color. If you need a new one you will find it HERE.
Good luck
Rocky
Posted on May 29, 2009
After my son vacuumed up maybe a lego theDiamond G Kirby started sparking from inside housing. We took brush and checked for any loose items and found none. Any ideas and can I diy?
Sucking up a Lego or similar item normally should not have done any damage to the motor. It may stop the brush roll which may burn the belt if the belt is tight. If the item got sucked into the fan it may have broken or cracked it which could seize the motor. Remove the brush roll assembly, spin the motor shaft while you inspect the fan. Fan replacement is best to be done by an experienced technician.
Jan 24, 2017 | Kirby Vacuums
Is there a motor reset button? power light lites up but no motor
Troubleshooting tips are found on page 51 of the G6 manual. This applies to most Kirby models.
This manual can be found at the below link.
http://ubermanuals.com/search/contentsearch/kirby
Mar 13, 2011 | Kirby G4 Bagged Upright Vacuum
My Kirby is not engaging the belt after it was put back on. I took it off to clean brushes and did everything according to the video but the belt will still not engage and green light does not come on.
The belt is not on the motor shaft. Remove the head from the motor unit. With the belt centered on the brushroll, turn the belt lifter a full 3/4 turn counterclockwise to stretch the belt up onto the belt lifter finger. ( Look through the back to be sure the belt is streched into a loop over the finger.) Plce the head back on the motor unit and latch it in place, then turn the belt lifter fully clockwise to drop the belt onto the motor shaft. Be sure the brushroll is correctly installed in the head. Setting # 1 should face the floor.
Dec 19, 2010 | Kirby G5 Bagged Upright Vacuum
How long is Kirby motor got warranty?
It depends. Did you buy it from someone who will honor the warranty? If not you may not have any warranty. Check first with the person you bought it from. You may find if you bought it from someone who came to your house to demo it the company you bought it from is no longer around or in business. Try to find a Kirby warranty center in your area. Be careful though, Make sure to get price quotes before any work is performed. I have many people tell me they took a Kirby vacuum in for maintenance or a minor repair and got hit with a $500 or $700 repair bill when they went to pick it up
Jul 21, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
Where can i download a user manual for a Kirby G4? Thank you.
I haven't found one that is downloadable, however, you can obtain one by calling Kirby at 1-800-437-7170.
Jul 07, 2009 | Kirby G4 Bagged Upright Vacuum
My kirby g6
Try taking it to a local kirby office and ask them if there is anyone in your area that can refurbish the motor instead of replacing everything. If that doesn't work ask a local dealer or call the dealer that you bought it from and tell them that you would like to trade your old one in for a newer one. I used to work for Kirby and I can guarentee that the Kirby itself, straight from the factory only runs about $200!
Jul 09, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G5 vacuum
check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
56 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
