Question about Microtek ScanMaker 9800XL Flatbed Scanner
Scanner gives poor quality scan...bulb?
I scan, but get about half good image then yellow line(1" wide) then red line (1" wide) then almost black....is this a bulb? or something really bad?
    Problem Solver:
  • 6 Answers
I have one with the same problem. Look at the lamp. If it isn't really bright, that could be the cause. Mine is bright at one end and that is the side of the page that is good. I am not an expert so I could be wrong, but that is where to start if all else looks OK. Am looking for a cheap replacement lamp myself. But at the prices of all-in-ones, it's not worth spending much.
Posted on Jul 16, 2009
When i scan on my Canon Pixma MP780 all in one printer, i get a light red line about an 1/8 of an inch wide down the scanned image?
Due to fact that the line is red makes me think the contact image sensor is faulty. If the line was black then i would have said you have something stuck on either of the scanner glasses. Check the glasses anyway for any muck stuck on them. Also do a scan from the adf and a scan from the flatbed. If the line is made from only one then the CIS is ok. If both do the same (a line) then the CIS IS faulty.
May 31, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Jul 08, 2009 | Xerox DocuMate 152 Pass-Through Scanner
HP4400c Yielding Poor Image quality
I was having the same problem- dpi didn't have any effect.
Changing the SHARPEN to "High" and Descreen worked for me. My research showed the alternative fix was a new scanner, or at the very least a new bulb/power supply (which would probably cost more than a new scanner)
Dec 09, 2008 | HP Scanjet 4400c Flatbed Scanner
Poor scanned image quality
yes u can repair this try to remove the cover clean up the white tiles which reflect the image, also unscrew it and clean up the mirror and lens
Sep 08, 2008 | Microtek scanmaker 3840
DR-5010C scanner yellow line
First clean the glass thoroughly using IPA (Iso Propyl Alcohol) Dont use any solvents. If you are getting the same result even after this, there could be a module problem.
S. Mohan
Mar 31, 2008 | Canon DR-5010C Path-Through Scanner
The image has patchy lines
The scan image you have above could be caused by a few different issues but the number one is a power issue. Make sure that the printer is plugged in directly to the wall and not into a surge protector or a power strip. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a copy. Does the image look any better?
If this does not solve the issue then it may be that your scanner bulb is going and therefore not illuminating the image properly. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
Feb 16, 2008 | HP ScanJet 2400 Flatbed Scanner
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Red vertical line through images
This issue does indeed sound like a bulb issue - however, it would be cheaper to replace the scanner rather than service the unit.
Mar 11, 2007 | Epson Perfection 1660 Photo Flatbed...
Microtek ScanMaker 9800XL Flatbed Scanner Logo
336 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
