Question about Pyle - PLMRA420 Marine 1000 Watt 4 Channel MOSFET Amplifier Car Audio Amplifier
Amplifier trip while cruising
I have installed a Pyle PLMR420 marine amplifierin my boat. The amplifier works OK for 20 minutes and trip activating the protection mode. It seem to happen while cruising and not at dock. DO you know if the pounding could be an issue, voltage ro adjustment?
  • edgardq Jun 02, 2009
    HI Audio20
    The system is hooked up from a Clarion CMD5 via RCA connections into amplifier. It work fine in the dock and I have attempt not to crank up and leave it low, still trip. The power cabling is gauge 8 and speakers 12.
    I will try to segregate eahc speaker one by one by disconnecting from amplifier to see if it shorts.
    Do you fill it could be also related to amp drawn, not holding by the battery?
    Any other feedback will be appreciated as the manufacturer response is ZERO, POOR SUPPORT
  • audio20
    audio20 May 11, 2010
    Just a couple things to consider while troubleshooting
    If everything works fine when sitting at the dock. Then you probably have some type of connections problem. It could be internal to the amp but it can also be a Speaker shorting due to the vibrations of the boat.
    Ensure all of your wiring is correct using the right gauge power wire etc..
    All connections clean secure and tight.
    Are you cranking it way up when cruising the input level may be to high for the amp?
    How is the radio connecting to the amp via RCA or High Level Input assuming you are using a radio and not a portable device like and MP3 Player?
    Problem Solver:
  • 5 Answers
Is it hot when it shuts off? from what you just described sounds like amp could have the "ohms" too low on a channel. Check you speakers with a meter. They should be no lower than 4 ohms.
Posted on Jun 03, 2009
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
I just installed my 10 inch square pyle sub and its hooked up to the dub amplifier..the amplifier is in safe mode and the subs woint hit..what do i do to fix this?
ok if the amp was in safe mode before the sub was hooked up then the amp needs to be fix , make shor the suds are hooked up right an the wires arent touching , the amp is in pro mode so there for u have to find out more on why the amp is not working or let me know what is goin on with it ,
Jul 19, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
How do i connect multiple ampliers to one source and equalizer?
why do u want to use 3 amplifiers connected in series ?or even parellel.?remember in series amplifiers 1+1+1 does not make 3.it may make 10,hence the speakers may go bust .
Aug 24, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Where do i can find the electrical diagram for pyle pla 2170
There isn't one. You will need to contact Pyle and I am almost certain you won't be able to get one for free. Expect to pay $20 for one
Jul 29, 2009 | Pyle PLA2170 Car Audio Amplifier
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
I am trying to wire and bridge a sony marine 600w sony marine amp
as long as the speakers are wired in parallel it should be ok dont wire them in series as they will overload the amp it is designed to run at 4 ohms
Feb 13, 2009 | Sony XM-2150GSX Car Audio Amplifier
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Car Audio & Video Logo
164 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
