Question about Sharp FO 5700 Plain Paper Laser Fax
Blank print top 1 inch has print Toner cartidge has been changed
Top 1 inch has print the rest of page blank
If you receive a fax and it is like that probably drum.if it is when you make a copy could be you optics
Posted on Feb 01, 2010
  • 48 Answers
I need more information. If you make 20 copies do you still notice the problem or only when you receive a fax. What is your copy count (press life 1). Does it jam or make noises. At first glance I would say phone line problem. .
Posted on May 27, 2009
The pages are not printed
sometimes in this case the dram needs to change (
Mar 01, 2015 | Samsung CLX 3185FW - multifunction fax /...
I am getting a blank stripe top to bottom on every printed page
You write "I am getting a blank stripe top to bottom on every printed page". You didn't say copy or scanned pages. Change the toner cartridge.
Feb 04, 2011 | HP LaserJet 3050 All-In-One Printer
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
Canon MF5750--copies come out with black streak (smear) from top to bottom of pages when printing. Changed cartridge and cleaned window.
run twenty blank pages through the printer by printing just a period (.) on a document. Otherwise the sheet should be blank. This is a way of cleaning the toner or inkjet ink from the printer. By the time the twentyth page is printed, the page should be clean. If not, you may have to get the printer serviced. The canon service number is 1-800-423-2366 option 1.
Jan 28, 2010 | Office Equipment & Supplies
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Sharp AR-5132 blank copy
see comments, loose blade by roller, push in, fixed
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Nov 21, 2008 | Samsung SF-560 Plain Paper Laser Fax
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Sharp FO 5700 Plain Paper Laser Fax Logo
99 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
