Question about Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Auto focus does not work on the 135mm
On my Canon 28-135mm f/3.5-5.6 EF IS USM AF auto focus does not work on the 135mm for the close subjects (more then minimal focus range) it moves right left for 10-15 seconds, and then gives me a completely blur image. I have Canon 40D it happened after i used the 50m f/1.8 lence
  • libin_michae May 31, 2009
    So can yu tell me if it is fixable or I need a new lens?
    New Friend:
  • 28 Answers
Hi i am sagha a camera repairer from mumbai, i have gone through such problems much oftenly,in your case i think it is the internal problem with the flex board inside the lens which is multitwisted on metal plate after prolonged use becomes stiff & brittle and creates hairline cracks on the pcb which in turn breaks the tiny tracks & leads to malfunction at 135 mm.
Posted on May 30, 2009
My canon lens 28-135 produces focused pictures but looks fuzzy in the viewfinder...is there something that has to be cleaned?
If your camera has a viewfinder diopter adjustment (small wheel a the side of the viewfinder) try moving this up and down to see if that corrects the problem
Sep 03, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
How to take apart Canon EF 28-135mm f/3.5-5.6 IS
Having gone over a month with no response, I assume this is no longer a problem.
Jul 02, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
May 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
18-55 lens not doing auto-focus
I offer you to buy Canon EF 24-105mm f/4 L IS USM Lens. This gives very good performance for your studio work and specially for portre. It has Image Stabilization and Ultrasonic Motor. Other professional lens are very expensive. It has red ring.
Please check the link below.
http://www.the-digital-picture.com/Reviews/Canon-EF-24-105mm-f-4-L-IS-USM-Lens-Review.aspx
Regards
Apr 13, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Scratched front lens element
Well, you cannot buy the front element by itself. The whole front optic set comes as a unit. You can call Canon USA, ask for parts,
1-800-828-4040
The part number you are inquiring on is: CY1-2800
Have you taking any pictures with the lens? usually it takes quite a bit of damage to effect images. The rear optics are the more sensitive glass on all lenses
Oct 03, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Autofocus on my Canon 28-135mm f/3.5-5.6 EF IS fails
Hello. First, check the contacts on the lens mount--you're looking for bent pins, oxidized(odd-colored) metal, damaged contact points, etc. The camera must communicate reliably with the internal circuitry of the lens unit. If there is any dirt, moisture, intermittent contact going on, the sensitive focusing electronics will be effectively blinded. If all is fine with the contacts, then the problem lies with the circuits in the lens that provide critical focusing data to the camera. Movement of certain parts causes electrical changes to occur at a calibrated rate--if the camera loses connection, it can't tell if the lens is actually adjusting. You'll have to send the lens in for repair--http://www.usa.canon.com/consumer/controller?act=SupportIndexAct. This address should get you started.--Hope I helped!---Rick
Mar 19, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens Logo
445 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
