Question about Haier Refrigerators
Can't find the drip pan
Haier refrigerator, I cannot find the drip pan
  • sabyl_sylver May 27, 2009
    Thanks for the response, I wasn't sure it posted.
    Haier, top freezer HTP18GAWW
    I know it isn't in the front bottom, and I can't seem to see it from the back
  • 4,889 Answers
Please tell me whats the type of refrigirator you have. If its a frost free then the drip pan , in most cases will be at the bottom of the refrigerator. If it is not accessible then you may need to empty your fridge and lean it against a support to access it. If you can specify the make and model I can offer you more specific advice.
Posted on May 26, 2009
There is no drain pan below my refrigerator
if there is one meant to be there
contact place of purchase
today I cant see a Haier Refrigerators drain pan for sale online
you may have to improvise with a plastic cat litter tray
or something that will fit in the space
Oct 12, 2016 | Haier Refrigerators
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
I have a Haier Air Conditioner window unit that is leaking inside the house. What are some possible causes and solutions?
There are basically 2 causes:
1. The rear of the AC unit is not tilted down enough, so that water in the drip pan flows to the drain hole in the rear of the drip pan. The general rule of thumb for rear downward titl is 1/4" to 1/2".
2. The drain hole in the drip pan, near the rear of the unit is clogged. Locating the clogged hole can be a challenge, as the clog will blend in with the drain hole. Patience & persistence are needed in locating it. A pipe cleaner works well to clear the clog from the hole.
Hope this helps you and thanks for choosing FixYa.
Aug 17, 2011 | Haier (HPE09XC6) Air Conditioner
Drip pan constantly filling up on haier fridge and not cool inside
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 20, 2010 | Haier HTQ18JAA Top Freezer Refrigerator
Refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Sep 11, 2008 | Refrigerators
Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Jan 03, 2008 | GALAXY Microsystems 63702 Top Freezer...
Refrigerators Logo
328 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
