Question about Kenmore Washing Machines
Water softener filling up with water
Hope you could suggest something else...
I have a Kenmore water softener, I have it bypassed now as it was just filling up with water. I know alot about water softeners, worked for water treatment company for 8 years, even serviced them...but they were not Kenmore. I have tried everything to get the softener to **** the water out. My experience is that the first cycle should pull water/brine out and then start its cycle. This one however does not seem to pull. I have cleaned out the float and the brine tank as well as the assembly on the side, as per the manual etc. It all seems fine but when it is finished its cycle, it has more water in it. then over the days, it gets higher and higher, my thoughts are that it still not pulling the brine...any other suggestions?
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
  • 26 Answers
SOURCE: the softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Posted on Dec 19, 2008
  • 401 Answers
SOURCE: stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
Posted on Jan 18, 2010
Testimonial: "Suggestion worked, but didn't really snap off. Had to wiggle dispenser & finally able to snap it out. Cleaned with a toothbrush and snapped back."
keithd2704
  • 56 Answers
SOURCE: The Softener is not going through.
Hey Ben Fixit,
Depending on what unit of Nexxt 500, not all of them have a slide out soap box. The unit I have of the Nexxt 500 series only has an access lid that lifts up.
To address the blockage on this style of machine, a user can start with a kettle of boiling water and slowly pour the water into the fabric softener well.
Remember fabric softener is made with plant fats and during the colder months can coagulate and clog the lines. This is due to the colder temperature of the water, especially if the user does not use hot water to wash all of their clothes.
Keith
Posted on May 31, 2010
Andriod Man
  • 271 Answers
SOURCE: The fabric softener dispenser in
I need the complete model# from the label to help you out.
Posted on Feb 07, 2011
How do I reset salt level
On the left hand side should be button marked salt level, after adding product,on side of brine tank are numbers in yellow telling you the level,push salt level button to the number shown on side of brine tank. Note: do not fill over brine tank, I suggest to fill to level 6 or 7..
Oct 31, 2014 | Kenmore Ultra High-Efficiency Water...
Will recharge/backwash clean out sediments
You can try several regenerations to see if it helps. But if the well guys did not "by-pass" the softener when working on the well and all that C!!##p got into the softener it is probably toast and either needs to be rebuilt or replaced.
RJH2O
Aug 12, 2014 | Kenmore High-Efficiency Water Softener
I'm getting a white film on my silverware that doesn't want to come off. Any suggestions?
Check water quality for calcium deposit. Use water softeners if needed.
Check rinse aid compartment and fill if required.
Sep 15, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
Stackable softener dispenser stays filled with
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
My water softener seems to be working, but my water feels nasty, like it's not working
If you have a three valve bypass the center "bypass" may be open and letting hard water past softener.
RJ
Dec 23, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softener goes in at wash cycle rather than rinse cycle
if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
Bleach dispenser Kenmore Elite HE4t Model 45986400
is the machine level or is something plugged anywhere?
Mar 27, 2008 | Washing Machines
Washing Machines Logo
360 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
