Question about Microsoft Windows Vista Ultimate Edition
Unable to enable ntfs compression in vista (hard disk-"all drives
I am unable to enable compression in my windows vista ultimate x64when i tried to its saying ''compression is currently disabled for this volume''i tried the regedit method and modified the key ''ntfsdisabled compression to 0''but still its not working its getting automatically reset to ''1''i am running only 90mb free space in "c drive" and even in other drives also the same problem(hard disk) pls help me with this problem
  • playboycenso May 26, 2009
    system restore is currently enabled in all drives but " c drive don't have any restore point"
    Scholar:
  • 57 Answers
Compress an entire NTFS volume
unable to enable ntfs compression in vista (hard d - warning.png You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
bullet.png Double clicunable to enable ntfs compression in vista (hard d - bullet.png Computer on the desktop.
bullet.png Right-click the volume you want to compress, and then click Properties.
bullet.punable to enable ntfs compression in vista (hard d - bullet.png In the General tab, click to select the Compress Volume to save disk space check box, and then click OK.
bullet.png In “Confirm Attribute Changes”, click the option you want.
You may have already attempted this but Maybe not....
This error usually happens in Linux but occasionally within windows.
My apologies if this does not help.
Posted on May 26, 2009
Formatting from RAW to exFAT does not work. computer (Toshiba satellite W7) says unsuccessful
How to Format Hard Drive With Windows 8 eHow
Step 1:
Back up all data on the drive you want to format. Tap the "Search" icon on the Windows Start screen and type "format disk" in the Search field. Select "Create and Format Hard Disk Partitions." The Disk Management utility opens.
dff89d62-f4c0-4d6e-b10c-7cba410b4b66.pngSelect "Create and Format Hard Disk Partitions." (Image courtesy of Microsoft.)
Step 2:
Click the drive that you want to format. Note that in most cases "Disk 0" is the drive with the Windows operating system on it. If this is the disk you want to format, you should reinstall Windows instead.
2fe0d696-372b-421f-b49f-da062aabbeec.pngSelect the drive you want formatted. (Image courtesy of Microsoft.)
Sponsored Links
Step 3:
Click the "Action Menu," select "All Tasks," and then click "Delete Volume..." Double-check that you have the right drive selected. The selected drive is shaded with diagonal stripes.
531c247a-9340-42a7-a785-35c37c5490ba.pngSelect "Delete Volume." (Image courtesy of Microsoft.)
Step 4:
Click "Yes" at the warning that all data on the partition will be deleted. After a few seconds, the volume is deleted. The drive is now listed as unallocated in the Disk Management window.
d35f80cd-51ea-4d05-8911-98dcebc0c93d.pngDisk Management warns that all data on the partition will be lost. (Image courtesy of Microsoft.)
Step 1:
Select the drive you are formatting if it isn\'t already selected. Click the "Action" menu, then "All Tasks" and "New Simple Volume." The New Simple Volume Wizard opens. Note that if the disk is part of an array, advanced users will have additional options like creating a new spanned volume, striped volume, mirrored volume or RAID-5 volume.
94a33b72-44e6-461e-9920-f69735d78d0a.pngCreate a New Simple Volume (Image courtesy of Microsoft.)
Step 2:
Click the "Next" button in the New Simple Volume Wizard so you can specify your preferences.
2b3d2635-9525-4ee5-a259-c38b5ba47fbf.pngThe New Simple Volume Wizard opens. (Image courtesy of Microsoft.)
Step 3:
Specify how much space should be used in the new volume by entering a value in the text field. If you are creating only one volume or partition in the drive, this number should be the same as the maximum disk space displayed above. Click "Next."
40a2b160-a7c4-4669-9f7b-9acdec319786.pngSpecify the volume size. (Image courtesy of Microsoft.)
Step 4:
Select a drive letter that you would prefer the computer to use for this drive. If you don\'t want a letter assigned, click the "Do Not Assign a Drive Letter or Drive Path" option. Advanced users may also prefer to mount the drive in an empty NTFS folder. Click "Next."
a7adfda9-4b8d-4ac9-8d3f-f9ffd7313665.pngSpecify a drive letter. (Image courtesy of Microsoft.)
Step 5:
Select a file system for the volume. Your options are ExFAT or NTFS. Use ExFAT if you\'re going to share files with a Mac computer; otherwise, NTFS is the better choice. Unlike its predecessors, ExFAT can support the same volume sizes as NTFS -- up to 256TB. However, it\'s not as robust as NTFS and doesn\'t support file system-level encryption and built-in compression. Mac computer\'s can\'t write files to an NTFS drive.
9a87dfc0-3bf5-43bc-9c8b-f51801f8795b.pngSelect a file system. (Image courtesy of Microsoft.)
Step 6:
Select the "Perform a Quick Format" option if the drive doesn\'t contain any private information, or if you\'re using the drive for your personal use. A Quick Format takes only a few seconds, but the data it leaves behind can be easily recovered by anyone with the right software. A full format takes much longer but it does erase every byte of data. Select the "Enable File and Folder Compression" option if desired. Type a name for the volume and click "Next."
3e35ad5c-5391-4201-a130-a49a67a41fd4.pngChange the volume label if desired. (Image courtesy of Microsoft.)
Step 7:
Click "Finish" after reviewing the settings that were applied to the new volume. If you want to change anything, click the "Back" button and format the drive again.
777198bd-fcb2-4516-b752-36d350d7ca61.pngClose the New Simple Volume Wizard by clicking "Finish." (Image courtesy of Microsoft.)
Step 8:
Select another drive or volume to format, or exit the Disk Management utility.
Read more : http://www.ehow.com/how_6026_format-hard-drive.html
Tips & Warnings
  • If you\'re formatting a drive to give to someone else, or if you\'re disposing of a drive that has sensitive information on it, you should always deselect the Quick Format option so Windows can perform a full format. However, even a full format may not make the data completely unrecoverable. The only way to be 100 percent certain that data can\'t be recovered is to destroy the drive.
References:
Microsoft Windows: Create and Format a Hard Disk Partition
Jan 09, 2015 | Western Digital WDBPCK5000ABK - 500 GB USB...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
If you are running your computer under ntfs should your external harddrive be formatted the same instead of fats32. If it does can I move my back up from the external hard drive and move it back after...
The external hard drive can remain formatted as FAT32. NTFS and FAT32 are the file systems used by the individual disk drives, and do not effect the data being read or written (i.e., you can transfer data between the two with no worries about compatibility). There ARE differences, however, and many would suggest using NTFS to avoid some limitations with FAT32. For example, FAT32 drives have problems with individual files over 4GB. Formatting in NTFS is definitely recommended for people storing large files like video and other media files.
Yes, you can move any data you have off of your external hard drive (to your system hard drive or another external you use temporarily), format your external hard drive with NTFS, and then transfer your backups and other data back to your newly formatted external drive.
You can also convert the drive to NTFS; but I recommend backing up the data first anyway in case of (rare) problem during conversion. Here is a link that has directions for both scenarios (scroll down for conversion info) for Windows XP. http://www.microsoft.com/windowsxp/using/setup/tips/advanced/ntfs.mspx
The process to convert is similar for Vista and 7; here are the instructions from MS: http://windows.microsoft.com/en-US/windows-vista/Convert-a-hard-disk-or-partition-to-NTFS-format
Feb 02, 2011 | Western Digital My Book Essential Edition...
I have a freeagent go 500gb portable hard drive. Is it possible to divide it into two 250gb partitions?how?
yes it is possible. First you can use a partition software. The second is using the disk management tools, these are the steps.
1.To run Disk Management Tool, click on Start, right-click My Computer, and select Manage from the menu that appears. When you see the Computer Management window, click the Disk Management item listed underneath the Storage heading. You then see the main Disk Management pane in the right side of the Computer Management window.
2.Creating the partition: Unallocated space appears as an Unknown Partition in the Disk Management diagram, you can use it to create a new partition in some or all of the space. To create your new partition, you need to right-click on the part of the diagram that represents the unallocated space, the unallocated space has a black stripe running along the top and then choose the "New Partition" on the menu that appears. To create your new logical drive in an extended partition that has free space The free space has a light green strip along the top, right-click on the free space then choose New Logical Drive from the menu that appears. Now you will see the New Partition Wizard.
The Partition Wizard will asks you to specify the following:
1 The Type - Primary, extended, or logical partition. Your hard drive can contain up to four primary partitions, or three primary partitions and one extended partition. Choose the primary partition if you are created a partition in which you will install an operating system (this is unusual situation). Choose extended if you plan to create several logical partitions within it. The logical partition type is available only if you choose to create the new partition in an extended partition with some free space.
2 The Size - You may use the entire available space, or leave room for more partitions. The Partition Wizard will displays the minimum and maximum size for the partition, this is based on the space where it will be stored
3 The Drive letter or path - Two operating system on your computer. You may select any unused letter, but the wizard will offer the next available drive letter. To Mount in the following empty NTFS Folder, you need an NTFS partition with a drive letter on the same machine. You may select the "Do Not Assign A Drive Letter Or Drive Path" option, this will let Windows assign a letter later, usually the default drive letter.
4 The File system - The default is NTFS (recommended), but you can use FAT32 (not recommended) as well. Both NTFS and FAT32 will efficiently utilize disk space on large drives.
Note: NTFS has better security features, the better recovery capabilities after a major crash, and has file-level compression built in. NTFS will also give you the option of enable compression.
5 The Label - Type a name for the partition, name it something that will indicating what you will use it for, data files, my files, fatboy one, etc.
I hope this solution was helpful.
Aug 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i enable ntfs compression in vista x64
You don't want to compress your drive... it's really not recommended. And you can't de-compress it once compressed.
I will suggest buying a new drive; Harddrives are rather cheap, and cloning utilities will make the transfer of your data eazy peazy.
May 26, 2009 | Microsoft Windows Vista Ultimate Edition
There are a number of reasons for compression to be disabled, but check these two things:
The cluster size for that volume:
Compression is not supported on cluster sizes greater than 4KB
By default NTFS cluster size for Windows Server 2003 never exceeds 4KB
This one is less suspect, but another registry entry that MUST exist
for 'Disk Cleanup' compression to take place:
HKLMSoftwareMicrosoftWindowsCurrentVersionExplorerVolumeCachesCompress Old Files
Other thoughts:
The command line "compact" utility can be used to disable compression for a folder and, optionally, it's subs. This might be a suspect if it were invoked at any time on that volume.
PLEASE READ:
Before you invoke compression on a volume it's best to read this "Best Practices" article: http://support.microsoft.com/kb/251186/EN-US/. Compression can have a detrimental effect on performance if used improperly.
When I try to back up my computer files for Windows Vista using a Toshiba 320GB capacity portable external hard drive I receive the message that I need a ntfs drive. Can my external drive be converted to...
Yes, it can:
Before you begin, connect your external hard drive.
To format the drive with NTFS
1.
Log on to your computer as an administrator.
2.
Click on the Vista Orb right-click Computer, and then click Manage.
3.
Under Storage, click Disk Management.
4.
If the Initialize and Convert Disk Wizard appears, click Next. If the wizard does not appear, skip to step 8.
3e609ff.gif 5.
On the Select Disks to Initialize page, click Next.
84b8e54.gif 6.
On the Select Disks to Convert page, click Next.
330a86a.gif 7.
On the Completing the Initialize and Convert Disk Wizard page, click Finish.
a63fbd2.gif 8.
Right-click your external drive (which will probably be drive E or drive F), and then click Format.
f8f5f91.gif 9.
In the Format dialog box, type a name for your external hard drive, such as Backup Drive. Then, click OK.
7560a25.gif 10.
Click OK again.
0a517a9.gif Windows XP formats your external hard drive. Within a few minutes, your drive will be ready for you to use.
Jul 17, 2008 | Toshiba Computers & Internet
Does the fj270 recovery disk from ebay make the computer like new with a blank harddrive?
I am assuming you are going back to XP?
You will run into one major problem with this process, Vista is based of Windows NT which uses a NTFS file system. XP uses the old file system of FAT32, so just wiping the hard drive probably won't work. You will have to go into your partition and re-partition your hard drive before you intall the recovery disk.
If the recovery disk is designed for your computer then yes it will restore it to all factory defaults (including drivers and software that originally came with it.
If you are not sure how to do the partition then let me know I will try to guide you through it.
Mar 27, 2008 | Sony VAIO VGN-FJ270/B Notebook
Microsoft Windows Vista Ultimate Edition Logo
124 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
