Question about XRS 9440 Radar Detector
Fuse rating for Cobra 9440
After it blew, I lost the fuse in the cigar lighter plug for my Cobra 9440. What rating fuse should I use?
    Scholar:
  • 115 Answers
5amp...
Posted on May 26, 2009
  • James Williams
    James Williams May 26, 2009
    NOOOOOO
    Cobra Electronics radar detectors use a 1 or 2 AMP fast blow
    APologies.......
Fuse 12 20A keeps blowing. controls OBDII and cigar lighter
Hi John!
  • There is a short in the Circuit. Do not put any more fuses in it.
  • Take it to the Electric Shop to have it diagnosed.
Good Luck,
JP
Jul 03, 2015 | 2005 Ford Excursion
Cigarette lighter fuse in 2003 dodge neon keeps blowing
The cigar lighter is shorted to ground and needs to be replaced.
Apr 15, 2014 | 2005 Dodge Neon
Cobra xrs 9955
The simplest advice is to check the power connections. If connected to the cigar lighter / power outlet of the car, remove & reinsert the plug into the outlet.
Still no luck?
Try powering up the detector in another vehicle's cigar lighter / power jack. If it works - try again in your car. The problem is not with the detector, but rather with the installation in your car.
If wired directly to an accessory terminal or other place in the car, check the connection(s) and cable for damage.
If you can't try it in another car, try plugging another device into the outlet to see if it works or check and replace any blown fuse for the outlet. You should consult your car's owner's manual for the fuse box location - and the location and amp rating of the fuse for the outlet.
Check the power cord. Make sure the cord is fully inserted into the detector - not hanging in the jack. The opposite end - that goes into the cigar lighter / power outlet *may* have a built in fuse in the tip. You should check to see if the center tip of the plug unscrews to provide access to the fuse. If it does, replace any blown fuse with the same type and amp rating and try again.
If you were unable to check in another car and you are still unable to power up the detector, there may be an internal problem with detector itself. In this case, contact the manufacturer for additional help.
Jun 06, 2013 | Vehicle Parts & Accessories
The fuse keeps on blown in my corba model #xrs 9440..
check your cord for cracks, other than that you might not be getting a good connection where it plugs into your cigarette lighter. Make sure you have a strong spring inside also
Mar 25, 2011 | Cobra Vehicle Parts & Accessories
I rerouted the power for my Cobra XRS 9440 and I accidently reversed the polarity of the power cable when I plugged it in. It fried the detector... I'm pretty handy with circuits and soldering, I'm hoping...
Did you first check the fuse in the units power cord? The fuse should be in the part of the power cord that plugs into the lighter socket. A 2 amp fuse should be good enough.
Feb 02, 2011 | XRS 9440 Radar Detector
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
I have no cigar lighter hahe changed cigar lighter
Take wires out of cigaret lighter , then replace fuse , if fuse stays ok without cigaret lighter connected then something shortning lighter inside.
May 07, 2010 | 1993 Honda Accord
I have Mitsubishi eclipse '98 GS.Cigaret lighter just stopped working. Checked the fused and replaced but it's still doesn't work. I was using a portable compressor to pump some air in my tire. I need it...
so you replaced a blown fuse to the cigar lighter and it still dosent work?.. then the wiring was compromised before the fuse blew..you need to repair bad wiring to cigar lighter and/or lighter itself internally melted /failed due to your air pump asking for more electricity than the cigar lighter could deliver..once repaired do not use the air pump there again ..good luck
Dec 02, 2008 | Mitsubishi Eclipse Cars & Trucks
XRS 9440 Radar Detector Logo
379 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
Jason
Steve
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
